Looking for a tube amp
The radio has 4 MOSFET finals. He's not set on a certain size amp. I think it's just a matter of value, what's available and what will work with his radio.
Sent from my iPhone using Tapatalk
I have a buddy with an RCI-2995 (new one-4 MOSFET finals). He is looking to get a tube amp. Any suggestions or leads on a good match.
CbRadiosPRONTO
Heathkit SB 220.
Drake L4B
AL80 series
any amp with four 572Bs
Dentron clipperton L
Hunter Bandit
I was thinking those radios had 8 MOSFET finals. Never mind.
Single gs35b would be nice but buy your spares while you can. An sb220 is a good ssb amp but not enough duty cycle for an AM hammer. JMO. There some nice amateur amps out there with big ceramic tubes but check price and availability before making a purchase.
Good choices except for the DRAKE L-7/L-75/L-4/ L4B:tt1:....no amp of DRAKE should be relegated to such dreadful service as 11m:tt2:
All the Best
Gary
But It is an amateur radio it even says so in the advertisement:unsure:
http://www.rangerusa.com/95dx.html
Even PSK 31 capable???
All kidding aside and back to the topic, No single valve 3-500Z will handle that amount of drive the radio has for output.
Need at least a pair of 3-500Z, and since it is a mosfet best is not to detune them for lower output. Pair of 3-500z only needs 85 watts input drive for full output if the tuned tank is designed efficiently.
Other option is using an input pad. This will reduce the amount of drive into the amplifier and the radio will still have full output.
Then again if you can find an old 3-1000Z, or 4-1000Z, that would be a good tube to use.
