Low Volume
Check to see that D34 is not cracked in half. If D34 or Q24 goes bad, you'll get little or no AM volume. Check the base lead of Q24 for about 2/3 of a Volt DC in AM mode only. Should go to about zero in SSB and CW. If this voltage is not found, there is some problem with the mode selector, or the connection from the selector to R106, the resistor that feeds into the base lead of Q24.
That's where I would look next. Seen my share of cracked D34.
Reactions: freecell
d34 & d35 look visually ok, i work 3rd shift so my radio time is limited, i will try and check the voltage on q24 on my next day off. I did change the mode selector thinking that was the problem but nothing changed.
I'm on this same path with the radio I'm working on. On q24 the voltage goes up to 2.6 volts when I change to ssb or cw.
RCI 2950DX-70DX
Q24 is in the SSB/CW IF path, so should be "on" in SSB/CW.
Q26 should be "on" in AM only, turning the AM detection diode pair on.
EDIT:
Pre-DX models are Q24 D34-D35
One small comment;
  • - are you checking your headers from the FRONT Panel - to the Main PCB?
Why?
When someone works inside the radio - especially these integrated head types like RCI does - the sheer number of headers, jumpers and sockets they all go in, can be easily overwhelming for a newbie starting out on this.
So if you haven't already, at least in the future - take pics using your phone or a simple digital camera so you can see and review before and after the works done - so you can make sure you got it put back together right.
I said the above, because for this problem to isolate to just AM may mean a cracked solder joint on the main PCB - onto a MODE switch header line it's open - not making the right connections.
So that might mean a header is not; properly seated, or all it's pins; making proper contact, on the board.
It's not "just" a "bad part" issue, it may be from the pulling-seating and all the work done - that did this.
The other low volume issue deals with MOSFET's that are used as switches to turn on the Ground needed to make the particular speaker and it's output jack work. IF you owned an RCI 2950/70 from a given year onto present...
On top of...So many different RCI models using the same outline - the boards changed to suit the newer technology and did away with from the older parts, but still give you the "same radio wrapper" - which adds to this whole mess of identifying the right board at the right time...
What am I talking about? See below...
So Ad Infinitum and Ad Nauseam...
Reactions: NZ8N
This is a 2970dx. Am and fm are low on recieve. am -88 dbm 30% modulation is as low as I can hear a tone. fm -90 dbm @ 3khz as low as I can hear a tone. This radio came from a radio shop estate sale. A repair guy that passed away. I replaced d34 just in case. Even though it was not cracked. I tried another mode switch no luck. Here are some pictures just incase. Thank you for your time.20211014_165337.jpg 20211014_165322.jpg 20211014_165313.jpg 20211014_165250.jpg 20211014_165246.jpg 20211014_165233.jpg 20211014_165337.jpg
Step back and take a break a moment - I see some trace work on the bottom side I don't feel comfortable with...
Not sure of the area in and round that back panel - this may be where the problem is...
Either way - it's gotta' be looked into...
Reactions: kd0ldl
20211015_171553.jpg 20211015_171527.jpg 20211015_171513.jpg 20211015_171933.jpgreflowed d73 external speaker diode. reflowed header pins from face and on the board. and antenna input to the board traces checked no breaks. Still low recieve am and fm.
if you either offset your signal generator up or down 1kc, unmodulated (CW), select the proper sideband to detect the carrier. Or, if you can not move the signal source frequency, turn the RIT until you get a beat note, same thing.
Reactions: kd0ldl
Thank-you for your time. Ended up being L 5 coil being bad. Replaced and went from -67 12 db sinad on am, to -108 @ 12 db sinad. And can now hear a tone down to -120 no problem.
Reactions: NZ8N and Handy Andy
