Midland 79-892 Low ch
n4dxx
117
27
38
Trying to get this radio to go down to cover 26.755,Has the PLL02A,I iknow they are differnt from say the Kraco AM only boards..I have tried all i know and i can only get high channels no matter what i do..Can't get it to go down at all..I know there is a way but can't seem to find in onlne.Anyone here have info on this radio?Thanks in advance
I'll need to dig out Sams CB180 when I get to work. Seems to me this is a 'reverse' PLL radio. The binary codes count down as the frequency goes up. This tends to require that two or three pins of the PLL get their logic state modified to go below channel 1.
Pretty sure taking loose one or more input pins that are soldered to high or low is part of the picture. Pins 8 and 9, pretty sure. It's all about the arithmetic. The Sams has that part of the picture.
Reactions: Cable Guy and n4dxx
Thanks i'll be on standby
Here are a couple of links you may have, or not. Information on the O21
If you have them, sorry for the repeats.
This model was my first SSB radio and escalated my radio world. With a Radio Shack 1/2 wave omni and the stock radio I was able to talk the world...in the late 70's early 80's. The clarifier built into the mic was a cool feature.
Those mods only work on AM only boards as far as i know..Thanks
Disclaimer: I haven't actually tried this and I have no idea what your soldering skills are. So don't blame me if you fry your radio.
SSB PLL02a chassis. You could try swapping out the loop mixing crystal. 10.0525 Mhz should give you 40 below.
Then there's playing with the PLL programming pins. The N-codes on the SSB chassis go down numerically from channel 1 (N-code 255) to channel 40 (N-code 211). So with that info we can probably figure out what to hack to make this work on 26.755 MHz.
We know what the frequency of channel 1 is, 26.965 MHZ. So let's take the difference between that and where you want to be: 26.965 - 26.755 = 0.21, or twenty one channels below 1. Since you have to count the N-codes up to go lower you would then add 21 to the N-code for channel 1: 255 + 21 = 276.
Which translates to pin 7 high, pin 8 low, pin 9 low, pin 10 low, pin 11 high, pin 12 low, pin 13 high, pin 14 low, pin 15 low.
After writing that I did a goofball search for "pll02a ssb chassis truth chart", and this was the first hit: https://groups.google.com/g/rec.radio.cb/c/_zVUdnc_lv0/m/6i3YBiOgd_gJ?pli=1
Dude wrote a frickin' bash shell script to calculate the entire truth chart for this chassis! It does confirm the N-code being 276 for 26.755, which is nice.
So, anyways, if you just tie pin 7 high, and pins 8 and 9 low, you should get 26.755 at channel selector position 39.
Or do whatever someone smarter than me (pretty much everyone here) tells you to do.
So when you say tie pin 7 high and 8 & 9 Low does that mean cut the trace to 8 and 9?sorry if i sound clueless but i am lol
You would have to cut the traces and then supply either +5v or ground. You don't want to just cut the traces and leave them floating. That leads to unpredictable results.
If you want to make it switchable, then we're talking adding some resistors and maybe some diodes.
No dice on Sams CB-180. Must be misfiled.
Typical method for this is to connect a 2.2k (or so) resistor from 5 Volts to the input pin, and then sever the trace that connects that pin to either +5 or ground. A switch that closes to ground attaches to that chip pin. A resistor that forces a data input to a logic high (binary 1) with no other input is called a pullup resistor. Closing the switch forces the pin to ground, logic zero.
Did you ever get the low channels on an 02A PLL SSB RADIO?
I stared at the schematic long enough to know that TM86 is right about the N codes (post #6). His mod should work.
I have never seen a frequency quadrupled before (the 10.0525 oscillator). Cool.
On these pll02a chassis doing the channel mod to go up/down they dont broadband power wise that good the chassis that have the 10.0525 mixer xtal.
Power drops off pretty fast. Channel lock from 27.855 down to 26.515 but again little power at both ends.
Has anyone have any tricks on tuning for better power?
I know the unidens have some tricks and the upd 858pll chassis have a mod on 1 of the dual transformers so u can get good power both ends.
working on fix with the 10.0525 mixer thats all set just the power.
Same thing would happen even if done with the pll little power
thanks
Reactions: brandon7861
thanks
Yea, that sucks. Considering the VCO mixer is combining 4x10.0525=40.21 with the VCO at 2.33MHz (for ch19) to get the difference of 37.88, the mixer products are going to be 2.33MHz apart. That filter be tighter than a nuns.... Probably a bad idea to broadband (not saying you can't, just that I wouln't without looking at a SA).
This may be helpful
Thanks cableguy> the vco is locking the full up/down band its the power and i did check the link u posted. I will have to check the 2 T4 and T5 both 27mhz transformers and see how they are wired in circuit.
The upd 858 uses the same mod where u cut a trace and jump to the unused pins.
Then retune and u get decent power across all the added channels.
