Palomar Magnum TX2250HD - Help
Robbo
Jan 19, 2020
3
2
13
67
Hi all,
I have a Palomar Magnum TX2250HD amp with a problem.
It stays on Tx after the mic button is released and some of the components get very hot. (resistors)
If you have any ideas, please let me know.
Also, I would like a schematic diagram for this amp, if anybody has one could I have a copy please?
Rob
Reactions: *Brett*
There are few designs repeated over and over again with many different names.
photos would help.
photos would help.
Hi,
I have attached 3 photo's, hope it helps.
Cheers
Rob
Reactions: Woody-202
Nice. Those were also made under the Bulletproof name. I have one that has two 1446 finals, I love the variable SSB delay on the back.
Hi all,
Rob
Hi Rob,
I just found your post, I hope you found a schematic, If not here you go;
Cheers
Brett 73
Reactions: Handy Andy
What length jumper between radio and amp are you using? Once or twice when using a short piece (1ft-2ft) cheaper coax between radio and amp I’ve run into a issue where the amp wouldn’t unkey.
Reactions: *Brett*
Hi Big Kahuna, I just checked a few of the jumper cables, that I have. All of them are commercially made, (bought ones) although from different suppliers, they are all 3 feet long (90 centimeters). You could also try wrapping a few turns of the coax around FT240-43 Toroid which will help with stray RF
Yeah I've known it to happen even with 3 foot jumpers on some of the "CB amps" with the RF causing the amp to hang on TX. Just thought it's something you might want to check. Have you tried turning SSB delay all the way down and see if it happens? Does it do it with the mic gain at zero, or only when you're talking?
That makes 2 of us...
A dirty switch or open wiper arm in the pot for SSB delay - can make a nice antenna to pick up RF and keep reinjecting RF signal to keep it in TX...
May not be the frequency you were keying on - (first clue) but it will "resonate" at a natural frequency - that means the amp needs some help.
Those front and rear panels use a "slide in" rail for those screws and are anodized aluminum, - means they insulate, so those pills are possibly the only ground that the amp really has - might be prudent to put some TLC into the screws and hardware. Even carefully undo the panels to gain access to the pills bottoms, that area takes in all their heat - and if it's not tight to the sink above (behind the pills flanges) it can add "things" to this problem you don't need.
Reactions: Crusher
Hello,
This thread is a bit old and I hope it is running. I found one like in the previous photos and was hoping to get some comments on how well it has worked or is still working. Was a fix to the issue posted, found?
I had this in storage for a long time.
Reactions: AudioShockwav
My take on this amplifier is that the relay that transfers the antenna from transmit to receive is just too small. Not enough current rating.
The receiver-preamp relay next to it is the exact same part. Big enough for that job, but not to handle the full output power of this amplifier.
Don't have an efficient fix for that.
I would thank Brett for the schemo, but he hasn't been seen for five-plus years. It has one tiny problem. D2 is shown reversed. Should point the other way.
Reactions: doffo
