Well…it seems I am having an issue.
The radio will lose signal, like it’s attenuated, and then regain after mic is keyed and released. It’s weird cause it can still make contacts. Coast to coast. I will recheck all the connections to make sure nothing is loose. The quick check I did…everything was tight.
I am using a modded Cobra M75 mic but that shouldn’t make a difference. Maybe bypass the KL203 and see if that could be the culprit? So weird. Even when the signal is “attenuated”…SWR is low. The only thing I would think is that it’s the radio.
Any suggestions good people??? I tired researching but found nothing.
Thank you!!!!
Thank you!!!!
