Questions about VFO options
Since the VCO serves both the TX and RX mixers in the 959, I think it could be done. It would not be simple though.
It is not just an L filter that needs to be changed, you also have a pi filter to re-tune, feedback at the final and driver to adjust (because the gain will be way higher at the lower frequency), a harmonic trap to re-resonate, and multiple tuned transformers (three cans in the RX chain and three in the TX chain) to shift to the new band. I think the capacitor feeding the RX front end would also need to be changed.
Since the frequency is going down, I assume adding caps to the existing tuned transformers may make them usable, but you would need the right equipment to get them resonant on the new band. I haven't thought about how the internal frequency counter will behave with this, IDK. Another question is if the new frequency will cause any mixing products that might cause problems with subsequent stages. And then where to inject your VFO signal to free you from the PLL's 40 channels and still allow RX and TX to work right. It would likely involve eliminating the PLL/VCO section entirely and feeding in your own VFO signal where the factory VCO was and bypassing the lock detect. I would assume this would work because the block diagram makes it appear that the RX and TX both use the VCO signal for front end (RX) and final TX mixing. I didn't study it very long though.
In this case, I don't see a 5 digit frequency counter being much use either, gonna need more digits. These factory counters are just for looks as it's 1kHz resolution will never allow you to dial in a specific frequency, SSB or AM. However, there is nothing wrong with spinning blind until you hear something (assuming you somehow stay within your license priviledges).
There are a lot of things involved in something like this and what I said is by no means a proper list of considerations. I only list some of these things so you have an idea what you are up against. If you have to ask how it is done, honestly, it's a bad idea to try. I know many cuss words would be involved and several days shot to $#!+ if I attempted it.
edit: As for the 980, we still don't have a schematic for that. The PLL is figured out, but without a schematic, someone would have to figure out the mixing paths and filter stuff and (m)any mods will be SMT.
Reactions: Illahe
Thank you for the detailed response.
I have nothing against the modern transceivers like the 891. Their price point reflects the two pill board and the band pass filter(s) in them, yet it would seem logical to have another 20M option. Thus affording the control operator an option of running an external amp of their choosing without being 700+ into the transceiver.
If this exercise is about not spending, then use the TS-130S you already have. If it is too big, or old, then get a used radio that covers 20m. Honestly, I don't know what your goal is here.
What I do know, is if you need to ask if you can get a Galaxy 959 onto 14 MHz, you are not going to.
I remember years ago seeing a youtube video, where a guy had converted a cobra 148gtl to 20 meters, Im not sure if it still exists, I think he explained some of things he had to do. I do not have the technical knowledge to convert a cb to anything other than maybe 10 meters. But i would compare it to swapping a Chevy v8 into a honda civic. Yes it is possible with a lot of fabrication work, and a whole lot of time invested. You are pretty much in uncharted waters, and it is not worth doing imo.
I like to think of it like this, you would always be better off starting with a car that is closer to what you want.
I remember years ago seeing a youtube video, where a guy had converted a cobra 148gtl to 20 meters, Im not sure if it still exists, I think he explained some of things he had to do. I do not have the technical knowledge to convert a cb to anything other than maybe 10 meters. But i would compare it to swapping a Chevy v8 into a honda civic. Yes it is possible with a lot of fabrication work, and a whole lot of time investe..............
We used to convert cb to 10 , Lou Franklin built his empire on it.
20 meters is doable but I agree it's likely a project.
Here's a starting point
( And I don't think the creator ever finished it but it's information)
Reactions: Illahe
Understood.
Awesome!
Awesome!
Is this an example of heterodyning? And is there a schematic? I would enjoy attempting a revision to create a "run" of SMT boards. Obviously I am not versed enough to design, but we have a lot of hobbyists in the club that would likely get a rise out of such a project for the winter.
For now I purchased a "china" QRP rig and intend to pair it up with a DX world e 12v board. Even though It will need a single intermediate transistor to boost the input from 3w to 10w, for 100w out of the pallet, I am looking forward to the project.
