Yeah so when you have a pile of gear running off the AC, you now have a second ground point. If you tie those chassis into your station ground, you will have a problem.....unless of course your station ground is tied into the house service with a low enough impedance path, but I would think it is a fraction of 1% of hams that have that properly implemented.
My station, the station ground is not tied to my service ground. So with this implementation, all the RF carrying pieces get tied to the station ground and the rest is floating with relation to that ground, but in turn tied to the service ground. I have only had issues if I cross the two of them up.
Well to be a single point ground it means that it is tied into the main ground for your electrical system, which includes your phone system, cable, gas, and any other ground. Anything less isn't a single point ground.
I have a perimeter ground system (2" copper ribbon around the whole property), tied into three ground rods, this system is tied into the electrical service ground. The antennas go to a copper bus bar outside the house (isolated) with stud mounted alpha delta lightning arrestors, cables go into the house (basement shack), The bus bar is tied to the ground rods with 2" copper ribbon. I have a copper panel on the wall in the shack, which is grounded to the bus bar. All filters, distribution, computers and other equipment is ground to that panel.
Yes it requires some work and planning (there is lots of info from commercial manufactures on the proper installation of grounding systems). I does cost a few bucks, but it can be done in chunks, and it is still cheaper than replacing all the equipment, house, or God forbid someone's life.
When I do put in my tower someday it to will be tied to the ground system.
To date since putting in a proper ground system no RFI, prior to that when I keyed up with 100 W on 20m my carbon monoxide detectors use to go off.
I agree many don't do it properly, but that certainly doesn't make the poor practices right.
The whole thing took me about 2 weekends to install, with the help of one friend, after you get the materials and have done the planning it really isn't that difficult.
