Random Crazy Amplifier build
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
10,674
12,354
843
Sierra Nevada by Yosemite National Park
The 4CW100000E is a ceramic/metal, high-power tetrode for applications requiring tube outputs from 100 to 250 kilowatts. It is ideal for use as a Class C rf amplifier or oscillator, a Class AB rf linear amplifier, or a Class AB push-pull af amplifier or modulator as well as a plate- and screen-modulated Class C rf amplifier. In pulse-modulator service, it can deliver a peak output of 4 megawatts. The tube is characterized by low input and feedback capacitances and low internal lead inductances. Its rugged mesh thoriated-tungsten filament provides ample emission for long operating life. The water-cooled anode dissipates 100 kilowatts when used with the EIMAC SK-2100 water jacket.
The guy claims it's for 11 meters........
Where's (what's) the driver? Whats it need for input power?
Can't wait to hear it on the air :)
edit: That's a little beyond N connector territory too. The feed line is probably going to cost more than everything else unless he goes to the culvert store and buys some 12" and 5" sections lol.
Reactions: AudioShockwav
They give you operating specs for class C RF. 120 Watts drive for 220 KW output. Grid driven, of course. The neutralizing capacitor's plates would look like the covers from an oil drum. No guidance on drive power needed for linear operation. 3-inch heliax might be too small. Unless it's located in the middle of a 40-acre plot you'll have RFI issues. Might make the rusty fence wires sing the way WLW did when it was 500 KW.
For full power you'll need water at 20 GPM with 19 psi delivery pressure. No advice on how big a radiator it requires.
I'm not sure that sheet metal cabinet door will block the fatal xrays warned about in the datasheet or protect against an explosion. That is also the first time I saw a fumes warning for beryllium. I guess with that input power, it wouldn't require grinding it. Scary.
Haven't tended to a "walk-in" transmitter in 50-plus years. It was a 1948 Gates AM broadcast transmitter. Had glass windows so you could see the color of the driver and final anodes. The driver-stage plate meter had been splattered and management wouldn't spring the bucks to replace it. We tuned the driver for dimmest glow from the 4-400 Anode. Kinda like "dipping" the plate current. But without a plate meter.
I think the owner of the water-cooled setup is dreaming.
Nice find and wish him luck!
Damm am I a duck...You'll need a side job just to pay the cost of lighting the filliment.
I hope he lives in a industrial park. 3 phase @ 500+ amps ain't going work anywhere else.
Them "AM" stations take it to the hilt. Talk about riding the lightning...
