short tilting mast
  • Start date Start date
B
BOOTY MONSTER
Guest
got my post in the ground for my little 18 ft tilting mast . its a 12 ft treated 4x6 a hair over 2 ft in the ground with 80 lbs of wet concrete . the top is braced to a 2x6 lag bolted to the rafter tails under the soffitt .
here's the finished idea .
theres a 1/2 inch bolt that will go in the bottom a foot off the ground . it will also go through the mast so it can pivot over .
thanks for the interest guys . i got a start on it and got the sections drilled for bolting together . i ran out of the real good black duct tape though , i hope to get some more tomorrow . im using it in strips layered along the length of the 1 1/2 conduit to make a nice snug fit by filling in the space between the outside of the 1 1/2 and the inside of the 2 inch . im gonna do a 2 ft overlap with a 5/16 nut , bolt and lock washer in the middle of the overlapping sections . heres a pic of what i got so far .....
i got it done , ill put a antenna on it over the weekend .. im tired and its starting to drizzle .
here's the bottom with the 1/2 inch bolt going through the 2 inch pipe and the 3 1/2 inch side of the treated 4x6 .
here's the bracket that holds it , its 2 of the 2 inch conduit brackets doubled up . i also added a bent rod to hold it in place while im taking the bracket on and off .
here's a pic of the other side i did 2 holes for the rod for either side
and here's a view of it from the deck . i angled the hole for the rod/pin down so wouldn't vibrate out
its seems plenty sturdy for a omni ...... i wouldn't put beams and a rotor with additional mast between them though . i think this would work pretty well with a freestanding 6x6 away from a house also . given the ammount of trees around the house , the deck and power lines on the 100 ft + towers back behind the house i didn't feel that wasn't a option for me ...... i didnt want the tip of the antenna directly under those lines :scared:
When you get the V4k on there, back up and give us a view of the whole thing in one shot if you can...
It's coming along very nicely.
thanks guys . a did a video of it tilting over , but it came out really dark . probably cause it was overcast and on a old digital camera , been raining steady about 45 mins now . yep homer , ill definitely do a far away pic to show the whole setup when its done . the feed-point is gonna be about 19 ft 6 inches , so with 31 1/2 ft of vertical the tip will at 51 ft .
i rent and i'm way too fat to be climbing on the roof :eek:
i also wanted to be able to have easy access to tune and tinker with it .... and possibly other projects in the future :D
  • @ Catalyst 122:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
