wanted: some type of 11 meters compatible beam antenna
Status
Not open for further replies.
Roll your own, Quads are cheap and easy to build, all parts can be bought at home depot HOMERBB has a thread about the outdoor loop that turned into a quad. Good reading
thank you I will give it a read... I am an avid DIYer / hobbyist... most likley I will end up just building something I imagine
but you know sometimes you get REALLY lucky when buying used gear
You can build a mono band antenna better quality than can be purchased.
Exception is multi band trapped yagi's, but they also can be made with coax traps, I am getting ready to build a multi band vertical using coax traps. Hope it turns out but the fun is in the building.
Status
