What is the tool to remove this nut called?
Cable Guy
Growth must be chosen again and again.
I Support WorldwideDX.com!
Dec 29, 2010
1,296
1,389
173
413-West Tennessee
I have to replace a channel encoder on a Stryker and they use a different style nut on all the front knobs. I have seen this before elsewhere and usually manage to remove them with a little effort and a lot of aggrivation. I'm not wanting to use that brute force tactic here.
Anyone know the name of the tool or where to get one? Thanks..
View attachment 77351View attachment 77352
Check your size, but here are some examples https://www.amazon.com/s?k=x+key+tool&crid=31E1WSPMIKI9E&sprefix=x+key+tool,aps,213&ref=nb_sb_noss_1
Reactions: Cable Guy
I believe they are called spanner nut wrenches. We'd make our own if needed be. Get a piece of thin tubing steel, aluminum works too, that fits over the pot shaft, file the sides down leaving two little dimples. Voila! Spanner wrench.RR-TOOL-SN-C2.jpg
45 degree circlip pliers work too and easier to find at tool stores. Might have to file the tips to fit. Bought a six-pack of el-cheapo mini's for $20 and machined them for electronics work.
