what would be a good base amp?
nomadradio said:
I was thinking the same thing!
One rule that makes good sence though is, "If you don't get enough power from TWO tubes, get bigger tubes!" In other words, 2 tubes MAX! A local in Long Beach has a box with SIX 3-500s. Its for sale too. A friend of mine asked me what I thought and I told him to run away!
Run away.Why? How much for the one big tube that will equal the performance of 6 Zs.How much for the transformers to run that big tube.A good example is the cost of 1000s versus 500s.
What tube gives you the most bang for the buck.Its all a matter of personal preference and how much money you want to spend.Most people are to lazy to tune and prefer transistor boxes these days anyway.I love my Zs. :twisted:
DuckKilla said:
Run away.Why?
Zs are great tubes! My favorite part is that they glow! My point is, that if 2 3-500s don't give you the desired amount of output, buy bigger tubes. This is good engineering practice and makes for a better amplifier. Nomad can explain it better I'm sure. Even the BIG broadcast transmitters use one or two tubes only. I have a 4CX35000 sitting here. Its one of two tubes from a Continental transmitter here in Southern CA. This transmitter is modulated with a pair of 3CX3000s. Again, we see only 2 per stage. If they could have run six 4CX10000 to save money, they probably would, if the could get it to work (this is just my opinion). Ask any REAL engineer and he will agree; no more than two!
There is a cost to play this game. If you want to play with the big dog, you need to ante up! No two ways about it. Will six 3-500s work? Sure; but not as good as a pair of the proper size tubes.
It's all about the economics. The guy who builds the thing will be aware of how many Watts of rating-per-dollar a tube offers. In 1975, the 6MJ6 tube would provide roughly 50 Watts plate rating (intermittent) for six bucks. That's eight and a third Watts per dollar. The 3-500Z tube cost around $150 at the same time, offering three and a third Watts per dollar. This is why the Phantom has ten or twelve 6MJ6/6LQ6 instead of one 3-500Z, more or less.
Best example of this I ever saw was in QST 35 or so years back. A military-surplus tube, the '1625' was a quarter or so each if you knew where to buy. It's about the same rating as a 6146. The fella wired thirty (30) of them in parallel. Ran it on 80 meters, so all that parallel capacitance didn't kill him. Used a half-dozen big power transformers from old tube-type console televisons for the H.V. The trick would never have worked at a much higher frequency, but a 30-Watt tube for a quarter gave him a ratio of 120 Watts per dollar more or less. Too bad it would never work on 27 MHz.
A few years back there was a rash of amplifiers built with the 250-Watt ceramic tubes built near here. Anywhere from one to seven of those tubes in them. The biggest reason was cost. He was getting surplus tubes meant for aircraft use. The filament (heater) in them ran from 26.5 Volts. Not one commercial base amplifier was ever sold that used those. Nobody wanted them, making the price as low as $30 each. Didn't matter that the filament ran at an oddball voltage. A 26.5-Volt tranformer cost him about the same as a 6-Volt transformer. That tube offered him the same eight and a third Watts per dollar as the 1975 sweep-tube comparison. Using any other kind of tube would have doubled or quadrupled his cost to make them.
Didn't make it a good idea, just made it cheap to build. Never mind about the cost of ownership. The more tubes, the more it matters that they share the load equally. If they don't balance the load, one tube out of two can only get pushed twice as hard as it should. Not good, but not fatal if you unkey soon enough. And don't do it too often.
If one tube out of six is "stronger" than the rest, it could get much more than just twice the power on it that it's rated for. The more tubes you've got, the more you'll buy to keep them matched, balancing the load evenly. If two tubes out of six fail, you may very well have to buy all six. Just to get six tubes that match evenly enough. If one of them is much stronger than the rest, a six-to-one overload will "POOF" a tube a LOT sooner than just two-to-one. Combining new, strong tubes with old ones usually will poof the newest, strongest one out of six. It will "hog" the load while the other tubes in parallel with it just "loaf", pulling less than their share.
A bigger tube may cost you more per Watt, and usually does. If the design is good, and the operator is sensible, it saves you money in the long run, in cost of ownership.
Another one of those "Pay it now, or pay it later" propositions.
Oh, and the broadcast equipment contains separate bias adjustments for each tube, so that they will "balance" properly. This also affects how cleanly the tubes will run. A really BIG deal with a broadcast transmitter. Purchase price is usually much less important than the cost of operating a transmitter for broadcasters. They'll pay more for a tranmsitter up front if it will make more money for them in the long run. That sentiment is usually not found in the CB/Ham market. Not often, anyway.
Strategies that reduce purchase price nearly always boost the cost of ownership in the long run.
Well over 15 years ago, I built some of those multi-tubed (4CX250B X 6) amplifiers, they were Cathode driven with each tube having a seperate bias control and metering point (phono-plug and 0 - 1 amp meter) and their standby current could be set individually.
I could even check the operation of a single tube during transmit by reading the amount of current that the tube drew.
FAA pulls from the local airport were cheap then.....
Reading all this about multi tube amps being dirty compared to a single tube amp??? I just ordered a RM KLV1000 which has five tubes!! Is this KLV1000 going to have my neighbors calling for bloody murder..... as far as TVI and bleed over or will I be ok with proper RF ground, Good low pass filter, and LMR400UF coax :(
  • @ wavrider:
    sea que sea que,
