WTB: Thrust bearing that's for common TV rotors
Mudfoot
Elmer
Jun 17, 2009
11,298
6,714
698
65
Southeast Ohio
I believe it's a TB-102
Anyway, I need one. I used to have one, but sold it. I've searched, but no luck. Hard to find.
Here's a picture.
Amazon shows the TB-105 bearing, but , "currently out of stock." Most places I looked said out of stock or discontinued.
Maybe this one from Yeasu will fit the bill.
https://www.dxengineering.com/searc...toview=SKU&sortby=Default&sortorder=Ascending
- 399
They've been out of stock for along time. I needed one for a project about 8 years ago and couldn't find one. Got lucky and found a NOS on ebay. It worked great, but sold it like a dummy. Sorry, but the Yaesu bearing won't work. The UTg105's work great as they allow a higher height above the rotor. Solid Signal doesn't even stock them.
Mudd -
Are you looking to take the vertical load off of the rotator, or lessen the radial deflection that the rotor has to handle ... or both ?? If a mast-mounted thrust bearing is not commercially available, you can make a suitable substitute using a pillow block bearing with a lock collar.
This would absorb all radial deflection, and could provide additional vertical support without suffering damage. Easily mounted to a small metal plate and held to the mast with suitable muffler clamps. Probably not too expensive. Just a thought
- 399
Mudd -
Are you looking to take the vertical load off of the rotator, or lessen the radial defection that the rotor has to handle ... or both ?? If a mast-mounted thrust bearing is not commercially available, you can make a suitable substitute using a pillow block bearing with a lock collar.
This would absorb all radial deflection, and could provide additional vertical support without suffering damage. Easily mounted to a small metal plate and held to the mast with suitable muffler clamps. Probably not too expensive. Just an thought
- 399
I was thinking about just such a bearing. The one you pictured looks like it has set screws to clamp onto the shaft/mast.
Could you not use a thrust bearing bolt onto a chunk of angle iron with a muffler clamp securing it to the support pipe?? Just a simple idea.
Reactions: Mudfoot
    boog351 has left the room.
