Yaesu FT-891 case options
View from end when operating it and leg propped up, and then tuner down in there. Buttons are accessible if needed. Radio works off the radio TNR button so shouldn't be necessary.
Showing a 30" coax jumper currently in place and other things if missed and the ground wire from tuner to radio.
this is showing the tuner level. Radio removed. It's kinda nice the case comes with 2 pieces of foam that are separate so you can let it out kinda in levels.
Reactions: Slowmover
Now. If you happen to run an LDG Z100Plus. I'd say try this. Radio on bottom (as shown). And just strap with velcro the LDG tuner on top. Or mold out the top included padding to fit the LDG and pop the top layer of padding out to run the rig.
2nd photo is extra padding that could lay across the top of the rig at least to keep it inline. Batteries have a 1 1/2" wall and when top is closed shouldn't flip or move.
Shortened some wires and drilled the hole for the antenna jack. PowerPole wire in middle is to go to my trickle 3 stage charger. Opted to not drill more holes for anything else's in the case (like a charging port)
Tac Comm
This is a pair of the large TRC-2
See the original TRC- 1
I have three. (So far)
Assemble radio, amp, tuner, power supply, etc, ready for use in carrier.
Get foam-lined APACHE 3800 or 4800 transport case to drop TRC into if not doubled by bolting
I found a SKB I-Series rolling transport case half off as a return. I figured on something large enough to also carry batteries & solar as well as that A-3800/4800.
With extra foam for different configuration, I can use this otherwise as a way of moving all radios.
(I’ve since gone to A-cases for each radio plus all gear they require to work. From power to wire dipoles and all in between).
But there are tools, supplies, test or diagnostic equip, etc that deserve best treatment.
If given antennas are disassembled for PVC tube transport, they also have supporting materials. Push-up mast, same.
Metal boxes and wooden crates have their place. Like, the 1907 journey across the Takla Makan. Or outermost layer should I ship by truck.
Remember portable dry kitchens?
Case big enough to “shelve” the cook pots. To start. Then utensils. Etc
Case(s), antennas, mast, keg-o-rator will need a plan
Be able to strap to one of these. Mines 400-lb capacity, but not heavy or bulky.
Find what couriers use.
Reactions: Mudfoot and CB590
