New profile posts
Studying for General. Researchig best HF antenna for my constrained, treeless, HOA-regulated small lot.
If you could only Mount your base antenna at 30’. What would you recommend? With what I have now I seem to get out ok. But my RX is hurting
Hello. My name is Cesar. I am in a situation similar to the one he comments on the forum. When it comes to setting up a CB team at the reception. They have left me a VTVM as the manuals say but I am not able to understand how to adjust the coils. I only see that in AC the needle varies when I move the volume potentiometer. Let's see if you can give me some clarification, thank you.
OK Got it... you used the IRF 9530. My bad. How did it go? I sell a bunch of the KL203. It is a good little amp for 80-100w out. Seems to handle 20w drive with no issues. I just keep RM3's and spare boards on hand.
sp5it
sp5it
Output is little less than original, but you can't go wrong with 1$ transistor :)
Did you really replace the little RM3 Mosfets in a KL203 with the larger EKL 9530 mosfet?
Any pictures? Surprised you found enough room. Be an interesting amplifier! Did you need to change any other components?
That is a good question I just like my tornado better because it is metal
Reactions: M.Bass
M.Bass
M.Bass
Have you had any issues with it? I don’t have the top measurements. But I have the radials out as far as they will go.
