House AC Current??? What does a CB Radio Pull???
DualAntennas
New Member
Oct 6, 2013
75
2
8
I'm asking because I live in a self-built solar powered home...
I don't want to overload
my power inverters
with my other appliances...LOL...
In House AC Current How many watts would a Cobra 2000 GTL Base
Pull from your wall?
40,60,75,100 Watts Like a light bulb???...LOL
Look on the back of the Cobra 2000. Like any other AC appliance it will have the maximum power consumption written on the back.
Not enough information , again!,how far have you got that radio turned up? If you built your own solar powered home you must have a volt meter and a watt meter.Why don't you tell us? volts x amps = watts . My best guess is between 60 and 100 watts.
Reactions: 4 people
Yes ,but that is before the magic screwdriver is used.
I thought of that then I remembered it's a Cobra 2000. The power transformer in that radio is nearly maxed out when the radio is stock. If you managed to screw drive any significant extra power out of that radio the lights will just dim as the supply falls flat on its butt.
my power inverters
They always said that a troll would reveal himself sooner or later and you just did. I guess you forgot about PM'ing me back in the first of November with this same question. Back then you told me you were looking at buying a back up UPS for when the power went out. Now you say you are in a self built solar home and don't want to overload your inverters.
Private Message: Re: How many Watts Does a CB Base Station pull from Home AC Power?
11-02-2013, 06:12 PM
DualAntennas
Quote:
Originally Posted by Captain Kilowatt
Quote:
Originally Posted by DualAntennas
This is NOT about output power!!!
I was wondering on average how many watts does a CB Radio Base station pull from your home AC power???
i.e. such as 40, 60 watt light bulbs???
Figure the current draw times the voltage to get watts INPUT. If the radio draws 3 amps at 13.8 volts then it is using 41.4 watts of electrical power. Allow for inefficiencies in the power supply (about 75-80%) and you get about 55 watts or so. Best guess is about the same as a 60 watt light bulb at most. Most stock CB's don't draw 3 amps and usually only about two amps unless it has been modded and peaked. That would make it about like a 40 watt bulb but only when transmitting. Receive is peanuts.
CK
Thanks I wanted to know because I'm thinking about buying a Battery Backup UPS for my CB's so I can talk a couple hours when the power goes out
they rate Run-time by watt's of what your running LOL
__________________
"On the Farm Everything always goes according to Plan;
Except the Plan is always Subject TOO Change!!!"
John Deere 16-Row Combine Driver
Any last comments?
cobra 2000 power req
this is a manual pointer..
Cobra 2000GTL
..click on the owners manual then a cpl pages in it gives the power requirements. 70w max on ssb. most folks estimates right on.
