Base Ultimax Dxtreme
The end of it is somewhere. Probably either where your router (command center) is located, or where the cable company is coming into the house, the outside connection box.
The end is in attic i Believe, as there is a bunch of coax cables lying up there I've seen. How do i check as my arms are not long enough lol
Also the socket where the coax is on the wall is much smaller looking than the socket so259 on back of rig.
That socket on the cable is smaller. Buy an F-connector to HF connector adaptir. I buy mine at Radio Shack (yes, some of them do still exist). Unless you have a Toner, or cable line tester, all you can do is hook something up on it and keep connecting/disconnecting in the attic until you find the right one.
