Transistor upgrade
Some times the best modification is none.
People that try this stuff with linear power supplies are almost always after one of two mystical creatures that can be proofed long before you even think about swapping parts:
1. More power
2 Cooler operation
They see something like more current handling and think.. more power, or it must run cooler!
Or, the device being able to dissipate more heat.
Or...... larger package.
(which people think means it will run cooler - but in fact it will just get to temperature faster because of it's improved thermal transfer)
If they did the math they would quickly realize that changing the devices will result in little to no gain. There may in fact be loss in the process. You make the problem worse.
The changing of regulators in virtually every case that I have seen or read about resulted in either zero or negative gains and every single time because the math just did not work.
Lest we get into how to properly de-rate the devices , which none of them even consider. Too much maths.... I want moar powah and watts!
You got it. In a case like this, no mod is better.
UNLESS..... it's one of:
1. reduced load
2. larger heatsink
3. design changes
And.. none of these are practical.
1. reduced load
2. larger heatsink
3. design changes
Plus most people do not understand "Compensation Networks" well enough to get the maximum out of the circuits. When you change a component that has a large effect on the regulation and response times are affected. Power supply switching noise could increase to the point of making it unusable.
When these transistors fail it's usually not from too much current. At 60 amps you're not likely to damage them from current unless you short the supply and the caps discharge through the pass transistors. Failures are almost always related to improper installation at the factory. I can't tell you how many times I've found parts mounted to the heat sink with loose hardware or little to no heat sink compound behind them.
Reactions: kaos513 and Tallman
We stopped repairing that power supply when the 30-Amp "brick" switchmode supplies dropped below 50 bucks.
Like this one:
https://www.ebay.com/itm/350W-Meanw...a5dade57:m:ma5yeFIs1QDEOhsB7n6suGg:rk:10:pf:0
This is what the factory uses in all of the 2995 base radios made in the last ten years or more.
It has two advantages. First, it has overvoltage protection. The original power supply with the heavy transformer does not. When those power transistors fail, they can fail as a short circuit. This puts up to 25 Volts DC onto the 12-Volt radio and linear. Things pop, not the least of which is the CPU/display board.
Second, it has a current limit. The original supply does not. The advantage of this feature is that the switchmode supply will protect itself if the radio draws excessive current.
Have you powered this radio from an external power supply yet?
If the power supply has failed, it's prudent to make sure the radio or linear doesn't have a fault that overloaded it and caused the old power supply to fail. Might want to know the full extent of the failure before you remove the old power transformer and supply, then install a new switchmode brick.
It's just the older Linear power supply versus the Switching style.
Linear consumes a lot more power to keep caps charged and dissipate heat from the dropping voltage across the pass transistors - all the time.
The newer design replacement makes more sense as it works like power on demand versus the constant regulation and loss in heating and cycling the older Linear design required.
Oh well...
Found a Darlington pair 160 WATT (Not amperes) in a top hat TO-3 design. PDF attached.
One word of note though, if you think about it - the part in the PDF would make a dynamite replacement drop in for the AM regulator - in a TO-3 design (or TO-204 style) - it has an Hfe of close to 4MHz so it's well suited for Audio passband.
So if you're looking into replacing the typical AM regulator - this part can suffice for driving the 9530
(forgot to attach the PDF! Sorry 'bout that!)
  • 2n6232Datasheetpowerregulator.pdf
There is a bonus to upgrading the radio to a switchmode brick.
Besides the big drop in weight.
Besides the current limit and OV protection.
The heat that the old regulator and rectifier were dumping into the heat sink is now gone. The entire heat sink's surface area is now devoted to the heat from the 2-transistor linear.
Only.
That heat sink is plenty large enough for the radio's amplifier without the need for a fan.
The fan is only necessary if the regulator and rectifier are dumping heat into the heat sink. The linear alone won't overheat unless you lock it down for a long, long time.
Wacky part is that the newer versions that are built with the switchmode brick are still sold with the fan kit on the rear.
But there is no real need for it unless you are dumping heat from a rectifier and regulator along with the linear.
Reactions: Crawdad7
Oh well...
Thanks Andy. I'm just hoping maybe it will allow it to run a little bit cooler. There's nothing wrong with it and I'm not looking to get anything special out of it. But I'm retired and I'm bored and I'm hoping well at a minimum maybe at least it will run a little cooler. Thank you so much for the help.
Reactions: Riverman
    63Sprint has left the room.
