These people know what EMP is and it's effects. It has been a major concern due to the complex computer systems on board ships.
https://www.history.navy.mil/resear...st-alphabetically/h/hemp-and-hpm-devices.html
You can get a brain coat.....
https://www.google.com/aclk?sa=L&ai...ahUKEwjSl-6ztr_hAhWq11kKHZB1BJUQww8ISw&adurl=
About the product
But at $58 + $6 shipping I think the Aluminum foil may be more cost effective. Guess I can just line my boots with Aluminum foil.
- Stretchy anti-radiation Silver-coated nylon skull cap with ear flaps
- Lightweight, breathable, comfortable & effective
- Microwave Shielding Effect: >35 dB at 1-10 GHz
- Surface resistivity: <0.5 Ohm/sq
- Thin enough to be worn under a conventional hat or all on its own
I haven't been inside of HEB store in 25 years. I miss the meat counter they had. Always a good selection and fresh.I'm headed to HEB, buying all their aluminum foil, wrapping the house. Anyone know where I can get leaded boots at?
Just get this paint. Rated at 37db attenuation.I'm headed to HEB, buying all their aluminum foil, wrapping the house. Anyone know where I can get leaded boots at?
Tall , That almost sounds like my Chicken coop !When I built it I read an article that said " Build it so a Predator Can't get in " So I lined the floor/walls w/ wire mess under the Ply Wood so they can't chew through , it also has a Metal Roof ! I know close but No Cigar ! But I wasn't thinking " Faraday Cage " back then . Now .... You got me thinking !
Where's them Damn Grounding Rods ?
