Actually I like the base set-up...
However the sweep does have an issue...Did you sweep it to see if it fell in anywhere?
I have this thought. The screws you used to hold the two elements together, were those self tapping sheet metal screws? If so I wonder if on the bottom section one was long enough to pierce the coax?
Possible also heating that shield to solder to the bottom section melted the insulation on the center. I say this due to your report that the VSWR in a 100KC sweep shows "infinity"...which means pretty much a dead short somewhere.
Also it's possible the center conductor solder is cold...meaning it is open and making poor connection
Check the coax with a VOM and check...center of coax to shield and see if it's shorted.
Also check coax center conductor to the top element to make sure you have continuity. Same with the shield.
The readings showing that high normally mean either a dead short or and open circuit!
All the Best
Gary
PS: where were you standing when testing? Just using the short piece of coax?
Could be you were standing in the "Field" of the antenna...I do believe though one of the issues is above as I mentioned.
All the Best
Gary
