Highs
Ziploc
Well-Known Member
Mar 19, 2016
299
136
53
54
Morning all, what’s the easiest way to tone down the highs on a comp 29. I know it would be on the top side of the board but what and were would I solder? Thanks
C69 by TR18 and TR17 in the middle of the board is the factory cap going to ground on the mic input. It is .01uF (103) stock. As sp5it says value is experimental. Try a .022 and if you want even more attenuation try a .047 or a .1uF.
If you meant on receive, make C134 higher in value.
Coo
cool
    boog351 has left the room.
