well second PS came today though I revieved a PM4 instead of PM3...will see how it goes stacking these, will post my findings.
Yes just hook up your multi meter or voltage gauge whatever, end adjust carefully with a small Philips driver and that be it.Are they eazy to adjust voltage, like a meter of some kind and screwdriver, type deal?
Got it: thanksYes just hook up your multi meter or voltage gauge whatever, end adjust carefully with a small Philips driver and that be it.
Can I ask what 75 amp power supply you ate using. Is it the MFJ or Ameritron? Those are the only two I know. ThanksI run a 75 amp on my n4. Works superb.
Posting to an old thread imo is better than stating a new one. It tends to keep info in one thread.You do realize this remark was nearly two years ago.
These are an alternative Power Supply. They are are battery chargers/maintainer. These might be use to maintain a bank of batteries. That's was what the PM3-75 is for me. PM3 V PM4 denotes # of modes. The 4th being constant set voltage output.
My PM3 does not have the Set voltage adjustment screw.
I see Staybolt last posted last week.
I have a PM3-75 (75 amps). It does not have the switch and voltage adjustment screw for the "fixed" single output mode. Perhaps this PM3 is an oddity and constant voltage output not enabled with this unit.Posting to an old thread imo is better than stating a new one. It tends to keep info in one thread.
PM3 Series Converters can also be wired in Series or Parallel to reach even higher power outputs.
Item link:
New Powermax 100 Amp Power Supply 13V-16V CB Ham Radio PM3-100LK Converter | eBay
Ideal for use in CB/Ham Radio, RV, Automotive, Boat, Car Audio, or any applications where battery charging and/or 12V power is needed. PM3 Series Converters can also be wired in Series or Parallel to reach even higher power outputs.www.ebay.com
When I was researching this awhile ago, I came to conclusion LK was key. That is, PM3-75LK has switch PM3-75 does not. So yours has the switch and voltage adjust screw?My PM3-55LK says it has 3 stage smart charging and Fixed Output Modes. It says it is Lithium compatible.
