SS 3900
Standard low power with noise reduction. On sale now.
A brand new take on a classic radio, the classic looks of the 80's version with completely new up to date internal circuit board. Offering the best of both.
This new model is a legal multistandard CB, operating on all the legal European bands. Simply select the country you want to use it in, and the radio will set itself to the legal frequencies & modes for that county.
In the UK it will work on the original UK 27/81 channels (on FM only) and on the EU bands in all modes (AM, FM, USB, LSB) with legal power outputs of 4W on AM/FM and 12W on SSB.
In addition to the "normal" controls on the radio there are also other features selected through a menu system - such as Noise Reduction Circuit (5 levels), VOX (9 levels), SWR protection, Voltage protection and mic selection (electret or dynamic).
The radio can also be expanded to cover all the bands that the original SS3900 covered - 6 bands from Super-Super-Low to Super-High (25.615-28.305MHz, with higher output power of 12W AM/FM and 25W SSB).
We can even supply the radio with an added "expansion" switch on the back, so that you can easily switch it from standard (UK legal) bands to expanded (for full coverage outside the UK) - this is just an extra £10.
Has anyone figured out how to get into the service/engineer menu yet? For some reason those who know are not giving the secret away !!
Those who know the 'secret' have realized that telling neophytes how to access the service menu often results in people bricking up their new radios. And those people then blame those who divulged the 'secret', rather than themselves.
This has happened on these very forums.......
And also because many of these radios require gear the average person doesn't have (such as a signal generator) to set certain parameters in the service menu that cannot be set any other way..........
Reactions: Pez
