I like to think of the DDRR antenna as half of a slot antenna with the end left open to account for the missing quarter wavelength (otherwise the feed point impedance would skyrocket being a shorted quarter wave stub). Maybe that explains the vertical polarization.
DB, I bumped the thread here because Shadetree was looking for info on the DDRR and there used to be some good links in this thread.It wasn't the DDRR that I was analyzing the vertical polarization models show, it was the Super Sinner, and later a dipole antenna mounted horizontally in the modeling software. The DDRR will definitely have a vertical component.
The DB
Looks like it's too close to the ladder rack?Just for information, here is John's latest DDRR like the one on his Jeep in his video.
This one is square, not round, he has said that it makes no difference between round and square.
View attachment 74886View attachment 74887View attachment 74888
I don't know, I have zero experience with these antennas, I know he was running one on his jeep, that was the one posted on YouTube.Looks like it's too close to the ladder rack?
Thanks Jeff, I saw his post on Facebook and asked the same question. I will update here when he replies.I don't know, I have zero experience with these antennas, I know he was running one on his jeep, that was the one posted on YouTube.
This is work in progress, if I hear more I will update.
He replied that a small adjustment on the tuning cap is all that was needed.Thanks Jeff, I saw his post on Facebook and asked the same question. I will update here when he replies.
Thanks,
Chris
Awesome!!!! I thought mine needed to be closer to the tin roof and not 12 inches away. I have not got to revisit this yet as I had some amps that came in for repair but I will get back to it and let y'all know. Thank you shockwave for this info, that helps for sure. I have the Rig expert AA-650 zoom to take a lot of guess work out antenna building but pics like this are golden. I will add a variable air cap to my next attempt to be sure I have all my bases covered.See below attached images View attachment 75053View attachment 75060View attachment 75061View attachment 75062
Air variable? Running barefoot? John said a 15kV vacuum variable barely handles an 8-pill, not sure air is the way to go there.I will add a variable air cap to my next attempt
