I used a good quality Vishay 2.2uf 50v cap. Though, others might be just fine. Polarity matters, so make sure it gets installed the right way. A search for type "MX3P relay on fleabay turns up multiple hits. Here's one of them:Could one of you guys supply me with the TRC 457 / 458 relay part number 3PDT 12 vdc coil, thanks
Nevermind... Scratch that idea....... I see it isnt even there on your picture and a couple others online. My TRC-449 mobile and the TRC-458 have that tantalum cap in place. Hope that info helps someone else who have similar radios.
Thank you very much for your share. I just bought an old TRC 457 last night for $50 and after cleaning on it for an hour that tantalum cap popped. Do you have any idea what would cause this. Just wondering if it will pop again when I replace it.thanksThere is a specific tantalum capacitor to replace on that board. Better to get a higher voltage rated one as its already working near its limits. MikesRadioRepair has a video on the Cobra 138 XLR restoration tips, and has the one to replace. I took a screenshot for ya. Circled in red.
View attachment 67335I used a good quality Vishay 2.2uf 50v cap. Though, others might be just fine. Polarity matters, so make sure it gets installed the right way.![]()
Was it while transmitting? I think that would of been the only time it would do it. It is already working near its limits from what I understand, so it probably called it quits and let go.Thank you very much for your share. I just bought an old TRC 457 last night for $50 and after cleaning on it for an hour that tantalum cap popped. Do you have any idea what would cause this. Just wondering if it will pop again when I replace it.thanks
