Anybody use switching power supplies?
Id drop 2 new ones in there. Look like hp possibly. Im sure someone could refit this with 2 new switchers.
Funny you say HP as I have seen some very similar looking hp units, will hang on to it till I find a few new ones
Reactions: Tokin
Well replacements were dropped in front of my door when I arrived home from work, so I hope to get them in on the weekend.
I know that I have seen tons of videos where people run their radios from old/used PC server switching power supplies. A lot of people say they don't see a noise problem, some say they do.
have any of you used one in radio service and, if so, what was your experience?
The reason I am asking, hook line and sinker..... I just picked up a used HP Server power supply on Ebay. This particular model is "screaming easy" to convert to 13.8V DC (snip & jumper OR....just jumper bypass a single 100 ohm resistor...and adjust the max voltage pot! This model is WELL KNOWN to work this way!
When done it will serve 13.8 VDC @ about 50 A max. I won't be using NEAR that.
The supply and shipping totalled $21.42 and I saw that as "worth it" just for the try.....
I have an MFJ 4125 which I have had many years.It's just used for a dual band mobile & some small accessories no heavy duty stuff.
SIX-SHOOTER
You are right. Talking about DPS600PB I mentioned before. For 20$ I get PS with over current, over voltage, temperature protection. Designed to run 24/7 full duty cycle in expensive equipment.
Small and lightweight.
No more linear PS for me.
Mike
I have some DPS600PB and have seen many mods with people using potentiomters to get to 13.7V, or completely disable OVP. Can you share a link to step by step instrucitons on how to adjust OVP properly for stable use? It would be MOST appreciated!
Thanks
Frank
I have used switching power supplies for about 10 years. The earlier ones I got were noisy but didn’t realize it right away so I just used them to run other stuff. Just recently I bought 100 switching power supply so I could run everything I have on one amp and it works fantastic. If you buy them from the same manufacturer, you could piggyback them also like if you have 2 50’s and together in parallel, you can get 100 A or close to it. I have a Texas Star 500 in the house on a 50 and 35 amp, switching power supplies hooked together, by the same manufacture. It drives the amplifier very very well and nothing gets hot. It’s warm but not hot.
Something I did wanna share I forgot about my last comment, try to keep the voltage around 13 or so I was running mine at like 14.5 trying to get the most out of the amplifier and all it did was fry the finals. I talk on sideband 99% of the time and it’s still fried the finals. My Radio Guy was telling me it’s cause I’m over driving them.
Reactions: Riverman
I use MEGA-WATT S-700-12 supplies to power my TX600 amp. Four in parallel @13.9vdc. provides 200 amps. Amplifier does 800W peak and the supply doesn't drop a tenth of a volt under load. Also use a 1 Farad capacitor as a current sink.
Absolutely no hash or other supply noise. Fans are quiet too.
- J.J.399
This is what I use. Megawatt 700 x 2 @14.2v for my DX-500. I use a separate one @14.5v for my Stryker 955
That's not true. Mobile amps are meant to run in an automotive environment. A vehicle runs between 14.4v and 15v when the battery is at full charge and the vehicle running. These voltages will not blow your finals.
Reactions: unit_399
