Problem with SM30 desk mic on Icom IC 7300.
ClaimJumper
134
63
62
I have an icon sm30 desk mic hooked up to an Icom IC 7300 and when I key the mic it makes a noise inside the radio. Kind of like a relay bouncing back and forth very quickly. Only while the switch is in motion. Is anybody familiar with this problem?
The problem has to be the mic switch. It seems like to me. All other microphones work fine. I was just curious if this was an issue for anyone else with the same microphone.
I'd check continuity with a multimeter between pins 5 and 6 of the mic plug while the mic is keyed to rule out the mic's switch.
Maybe an rf issue? don't know what mode you're on try turning the power and or mic gain down and see if either make any difference.
Wide open between pin 5 and pin 6. Power or mic game make no difference. The microphone works, and I'm using it. The action of the switch throw is what is causing the noise inside the radio. That noise stops when the microphone fully keyed. The point between receive and fully keyed is where the noise is. I use the lockdown key instead of the push to talk key. It's a different switch, and a shorter throw. I hope that makes sense. The blue switch is the lockdown. The black switch is the push to talk switch which seems to be the culprit. I believe it's just a bad scratchy switch.
I have the same mic and it does the same thing. I can see my external watt meter jumping as it chatters, but no one on the air hears anything.
Thank you! Now I can assume it's not my radio. That's exactly the same issue I have. Nobody else can hear it on the other end of the conversation. But it Chatters back and forth like a relay or something. I sent a query about it to Icom yesterday. We'll see what happens when they get back to me. Unfortunately I can't return mine I've had it so long. I never hooked it up until it was too late to return. I'm hoping they will cut me some slack.
What radio are you using? Just curious.
It's a damn shame. Like you say I get amazing audio reports. That's the only reason I keep using it now. But something's definitely not right. Well. I'll post here whatever I hear from Icom.
Sounds like you have the VOX turned on to me. I would check VOX & Anti Vox.
I would look at the edges of the PTT signal at the mic cable to see if you have ringing/switching noise.
Maybe the combination of that mics Pi filter and that particular radio creates a resonance. 100uH is pretty big for what it's doing (EMI filter I assume).
Try tacking a damping resistor across that PI network inductor (L4).
