Why would anyone use hifi caps in a CB radio, with a maximum of 2.4khz audio bandwidth? As long as the caps are reliable and can handle the voltage it will be perfectly fine. Good caps in the power supply of course.
What he's talking about is changing the values of certain capacitors in the audio chain to widen the response.
Bypass the filters and it will be wide as a barn door. Both limitations are on the RX and TX side.What he's talking about is changing the values of certain capacitors in the audio chain to widen the response.
