Anytone AT-5555N II (version 2). AM modulation swing and or SSB safe power output adjustment
I'm having difficulty with this radio trying to do a hard reset. The manual instructions don't seem to work...tried both OPT and ALL and it seems to have no effect on the radio. This one is the QT60 version, which shouldn't change anything, but who knows. Thanks in advance.
  • Haha
Reactions: Rwb
The radio plays fine and all settings in the service menu seem close to the list that's on this thread. But regular menu settings just never go back to default. A real head scratcher.
Reactions: Rwb
No. It says right at the top of the chart....
Anytone AT-5555N Original Service Menu Settings (First Radio V2)
So it is for the 5555N, which is an entirely different radio than the 5555N2.
There is zero need to go into the service menu on these radios.
There are parameters that can only be adjusted with the right service tools. If you change the parameter and don't have a freq generator for example, you CANNOT change it back to how it was !
I have the 5555N2 and it works 100% OK right out of the box. There is no need to adjust anything that can't already be adjusted in the regular menu.
Real Ham Operators love to experiment, not just key a mic and chat (appliance operators). We love to get our hands dirty, burn ourselves soldering and deeply inhale those whisps of solder smoke as we create or repaire ham gear.
  • Haha
Reactions: Rwb
Je voudrais avoir un renseignement s'il vous plaît j'ai la anytone ton 5555 N 2 et je voudrais avoir les réglages d'origine j'ai ma réception FM et am qui est bonne mais ne correspond pas au paragraphe comment remonter le signal dans le menu caché le SQ automatique n'est pas assez fort j'ai touché un peu au menu caché est-ce que je pourrais avoir à peu près les réglages d'usine si quelqu'un possède un Anytone 5555n2 même que je sais chaque poste à ses réglages d'usine mais c'est pour avoir une base merci
Chcesz, żeby ci pomóc to pisz w języku używanym na tym forum
as i posted a bit back and captain killowatt agreed,if ya gonna screw with menu settings first and i MEAN FIRST THING COPY EVERY VALUE AND ITS MEANING .if you screw up dont ask us but reset the values because NO 2 RADIOS USE SAME VALUES even 1 build number apart. extra work but easy to do from the getgo
From what I have read, the AnyTone 5555Plus (new version) and the Retevis HS4 are manufactured from the same "cookie cutter" and at the same bakery. The default value numbers in my new version AnyTone 5555Plus and my friend's Retevis HS4 are not exactly the same, but very close. AM Low and High Power numbers are within two to three value number differences. The most significant number difference is in Menu # 19, AM modulation. 5555Plus has a default value number of 217 and the value number in the HS4 is 160. We experimented with both value numbers and there was no noticeable difference between 217 and 160.
Reactions: Rwb and jrd426
I will say no radio should be "brickable" adjusting anything through the menu or data cable.
I own a Radioddity 60 Pro so much the same radio. Nothing should be brickable operating through the menu not even the engineering menu. This is just a sign of poor design. This is normal for China.
You should have to bypass layers of security and such to brick it at min. anything less and it should be impossible. So as an exaple adjusting the setting on your phone does not even come close to bricking your cell phone but if you try to jail break it or root it then maybe you might brick it etc!!!!!
I am 52 and I think that even a firmware update gone bad should not brick a glorified CB radio.
Nos itens de menu 19 e 20, defina ambos como 000000. A partir daí, defina os valores desejados.
Quero saber, se fizer isso então , deixar os menus 19 e 20 em 00000 eu posso alterar todos os 59 parâmetros do menu oculto, correto ? Você testou ? Pegou essa informação onde ??? Responda aí. Obrigado.
Os parâmetros do meu Anytone 5555 N2 são estes:
#1 CH-01
#2 CH-02
#3 CH-03
#4 VCOFRQ 00052
#5 VCOFRQ 00050
#6 TX- IQ1 00139
#7 TX- IQ2 00164
#8 TX- IQ3 00179
#9 FMPOWH 00163
#10 FMPOWL 00069
#11 FMRSSI 02855
#12 FM MOD 00250
#13 FMTONE 65350
#14 CTC 00052
#15 DCS 00042
#16 AMPOWH 00152
#17 AMPOWH 00099
#18 AMRSSI 01443
#19 AMMODL 00219
#20 AMMODL 00244
#21 AM TONE 65216
#22 UL POWH 00225 (*00255)
#23 UL POWL 00089
#24 USB PA 00007
#25 LSB PA 00007
#26 USBPWL 00113
#27 USBPWH 00224 (*00254)
#28 BPFUSB 00040
#29 BPFUSB 00105
#30 USBTON 65224
#31 LSBTON 65226
#32 RX BPF 00000
#33 TX BPF 00000
#34 UL SQL 00284
#35 UL SQH 03846
#36 AF SQH 03905
#37 AF SQL 00520
#38 ASQ H 00148
#39 ASQ L 00467
#40 AF RS1 00524
#41 AF RS3 02379
#42 AF RS5 02967
#43 AF RS7 03211
#44 AF RS9 3522
#45 AFRS 12 03905
#46 UL RS1 00283
#47 UL RS3 01618
#48 UL RS5 02866
#49 UL RS7 03168
#50 UL RS9 03474
#51 UL RS 12 03846
#52 RFG 00087
#53 SQH 00002
#54 ASQTH 00004
#55 WXFRQ 00235
#56 WXSQO 00078
#57 WXSQ1 00069
#58 V BAT 00100
#59 VER 100 (NADA FAZ)
Parâmetros do menu 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51 e provavelmente alguns outros, só se faz ajustes com osciloscópio ou nano vna usando gerador de sinais na frequência certa. Portanto MUITO CUIDADO !!! Onde deixei as marcações com (*254) e (*255) eu aumentei a potência em SSB do meu Anytone 5555 N2, ok ? Só mexi nisso !!! Observação: Se eu deixar o menu #27 em 255 não transmite, teria que mudar o menu #22 também. Aconselho até deixarem o menu #22 e #27 em 00250, ok ? Façam 1 teste. Meu grande abraço. Tem vídeos de amigos brasileiros que comentam sobre o menu oculto, tem que ter muito cuidado, algumas coisas se mexer já era, aí só um bom técnico de eletrônica/RF/rádio HF saberá resolver e arrumar tal erro. E lembrando, essas configurações são doentes meu ANYTONE 5555 N2, não tem nada a ver com outro 5555 primeira versão, esquece !!! Boa sorte.
