Anytone At-6666 Pro
It is happening. And it will be available soon, along with new firmware to support it.
I was told about the FW, but was told no ref osc adj for user, just "pro". Maybe they changed their position? I don't know or care. 20 Hz frequency error is nothing on any mode the radio supports.
Reactions: Rwb
Hi all,
I have just posted an update on a new AT-6666 PRO firmware update, PC Alignment (service mode) tool, and PC software here:
73,
Pez
Hello!
I'm new to the forum, I just bought an ATQ6PRO radio. I made a cooling fan with control. I did not drill the radio anywhere, if necessary, the fan can be removed. I set the control so that approx. 37C heatsink temperature with this solution.
The controller is very simple and cheap.
I hope I was able to add value to this community.
Sorry for the bad English, Google translator was my friend. :-))
Greetings: Csaba from Hungary
  • ATQ6Pro_ventillator_vezerles.pdf
Does anyone know when the pro will be sold with the new firmware already loaded ? Its looking like a few months here before i will be ordering mine so just curious. Thx!
So it's said the the newest batch of the qt80 are now available with the new firmware and the q6 currently offered by Scott's does as well.
That being said, it is pretty easy and straight forward to flash if you get/have a radio with the older firmware. BTW, the QT80 & Q6pro Firmware is slightly different (display name).
What do you mean by "display name"? The name shown in the QXCodePro3 firmware tool, or something else?
Reactions: Rwb
I think he means the default power up display.
Yeah, except these AT-6666 PRO / QT-80 radio's don't have a power up display at all.
(The AT-5555N2 and QT60 / PRO have the configurable display text, but that is programmed with the PC software, and is not stored in the firmware either).
Reactions: Rwb
I was guessing. My crystal ball broke, so your guess is as good as mine.
Reactions: Rwb and Pez
  • @ 357:
    holy man no activity or what?
    357 has left the room.
  • @ Hambones amps:
