BJ radionut
Supporting Member and 6m addict
Still true 2 years later
Quoted from old thread in 2008...boy did they unload on me then...all below still true...I am with you on this CK...
I figure this will most likely start a fire storm...but just my thoughts from the last few weeks with the band starting to come around...
MHO on good SSB operation:
1: Do not become a kronic QSLer
EX: QSL QSL Mike, I know what you mean I do it myself QSL...QSL QSL Mike I am running 25watts also QSL
2: Below 29.500Mhz...your Roger Beeper is turned OFF
no reason for it!
3: Turn off your feedback(talk-back) audio through the speaker...you sound like your in a 55 gal drum...
OK with headphones...but otherwise Nada!
4: You are never QRT/QSX/QSY or "On the side"
EX: how about simply "(your call)off and clear" or "(your call) now listening" or (your call) moving to 28XXX
5:QSK...does not mean break on SSB!
Simply state your call in a break in the conversation and you will be acknowledged.
6: Echo with ZERO sustain time and at minimum setting will be acceptable...if no one has noticed...otherwise leave it OFF...
7:They are not called PILLS in your Linear
They are transistors in your amplifier...
8: the term is 73....not 73's...and no other numbers are required either
9: There is no such term as CHECK,CHECK
Ok enough for now I know I have heard others lately just can not recall all of them this second...
No I will not make a big deal of any of this "On the Air" except those silly D*** beepers...
and I will politely ask that you turn it off...
I am just stating MO on what I think is good practice after almost 30 years with my call...I am not the prefect one...I have stood corrected myself...just my thoughts and now putting on the flame suit...
All the Best
BJ
no reason for it!
All the Best
BJ
