Hi all,
Mac from Circuit Domain here, I have read previous posts and I feel I need to correct or reply to few before you guys over analyze things in the long run.
1. Yes, You can always reach me on
Sales@CircuitDomain.com or just visit
www.CircuitDoman.com site and shoot your questions to me via the website.
2. Yes, there is a humming noise on some (1%) of radios due to the fact that the radio was not designed to handle digital circuitry. Very few, but noticeably surfacing have an issue. The problem these radios have is not an RF issue, it is the power supply design issue. ie. driving multiple LED segments (depending on digits being displayed) causes the problem.
3. r
ed97k1500 - Yes, I did send you the wrong information. MB3756 is where you pick up PTT not Squelch. I did spot this and sent you another email with correct information.
4. Shadetree Mechanic - Yes, prices are different in USD. I Don't have an "every hour" (not even every year) update on the current exchange rate set up for price comparison in my online shop. Thank you for pointing this out. I will fix it tomorrow, bit late here now.
However if you go through PayPal then you will always pay with current exchange rate even tho you used USD currency in my shop.
5. nomadradio - Thank you for pointing out that radio chassis is an independent floating GND. Well, RF GND, not common GND as "-"
And yes, your assumption in the way the squelch tap circuit is correct, In DigiMax Lite it is about Voltage difference (not current). The way this sensing wire is connected to the MCU via a voltage divider to arrive at no more than +5V DC. Never turn VR1 to it's extremes. Voltage at Pin1 of U1 must not exceed +5V
6. Allan, Thank you for your support. I have only just found this thread.
7.
loosecannon - Encoders being used are exactly the same kind as any one else uses, I have had only one complaint that "it just fell apart when I touched it" over the last 10 years. go figure
7. Any questions/problems etc. just email me
P.S. OLED coming soon..
