electronic cleaner spray can prices
General rule for using a "leaves no residue" solvent like the WD40-brand product above is for connectors, relay contacts or 'snap' switch contacts that the surfaces don't slide across one another.
Any rotary control has the potential for friction damage unless it has a lubricant film. As a rule that kind of control came from the factory with some sort of lube on it. A pot's metal wiper sliding across a resistance element needs this. So does a rotary switch with moving contacts that slide under fixed contact points. Slide switches. This is the distinction of a "control" cleaner compared to the non-residue "contact" cleaner.
Once upon a time you could depend on seeing one or the other of those two descriptions on the package.
And if you use a "dry" non-residue cleaner on a control that never gets the knob turned, probably no harm done. Wear only matters if you turn the knob.
Relays - no residue contact cleaner
Switch/Pots/Sliders - no residue contact cleaner followed by Fader Lube 100
I have one of these full of Fader Lube:
Amazon product ASIN B07P7R1TBF
Makes it very easy to get it where I need it and no mess.
Fader Grease on pots/sliders that I want some "stiffness" to.
"Hosa" branded Deoxit products are cheaper.
The WD-40 specialist contact cleaner is really good, they also do silicone lube and dry ptff. You can get it on eBay and Amazon. Deal on eBay at the minute, number 384914693174 all 3 400ml cans or 13.5floz for £21.99 or roughly $26/$27
Reactions: Rwb
