Everything was going fine until the third and final piece of the antenna put a stop to that.
The second part of the i max threded as easy as it should've.
The third and final (whip) section wouldn't thread into the second section of the antenna.
After a bit of checking which thread was bad, the female receptical or the the male end of the final whip.
Two different whips not associated with the I max that were the same thread size as the 2000's easily threaded into the female receptical of the number two section of the antennan.
The final whip section obviously had a faulty threaded tip and no matter how I tried it wound not catch the first thread of the receptical.
Job haulted!.
I will be getting another "new" third section sent to me but unfourtainarly will not be able to find the time to finish the install until next week.
Since my antennas on a non penetrating roof mount I taped a plastic bag at the top of the first section that was already bolted to the mast's and stood it back up.
The second and bad threaded section are in the garage.
I didn't want to leave the mast's and bottom section laying on the floor where someone could trip over it. So I stood it up.
what a shame!.
Has anyone ever had a problem with any of the threads on a brand new I max 2000?
I began taking pictures of the install until thing's went south.
I'm absolutely pissed! I'm positive these thing's only happen to me. As you can see the mfj 915 rf choke is installed and I didn't want to have to un-bolt the first section of the I max and start all over as all in need is the new whip that's being sent to me in order to complete
the job.
Job haulted!.
what a shame!.
the job.
