    Dismiss Notice
Dismiss Notice
Metal roof question
Discussion in 'CB Antennas' started by okie, Oct 17, 2019.
  1. okie
    okie Member
    Nov 5, 2010
    30
    18
    I am putting up my first beam this week and was going to mount it above a piece 30' of 2-7/8 oilfield pipe.
    With the pipe and a piece of mast, the bottom of the vertical elements will be only about 7 or 8' above my metal roof. Will the beam being that close to a metal roof cause interference? Btw, the beam is a Maco Y Quad.
  2. Unit 75
    Unit 75 "TRAINMAN"
    Jul 29, 2014
    484
    860
    It probably will. Being too close to the metal roof is going to mess with your antennas radiation pattern. If it isn't too much trouble try it and see what your match is like on both horizontal and vertical polarities. I think your horizontal SWR will be high.
    357magnum and midnight special like this.
  3. okie
    okie Member
    Nov 5, 2010
    30
    18
    Unit 75, thanks. What do you think is the minimum clearance I need? I have several pieces of 5' (1.5") Rohn mast pipe but I dont want to be too flimsy.
  4. Unit 75
    Unit 75 "TRAINMAN"
    Jul 29, 2014
    484
    860
    I ran the same antenna mounted on a pole/mast that ran upside the back of the house. I would say that the antenna was probably 12-15 feet above the metal roof and I had issues on the horizontal but the vertical was ok. I ended up buying a 45 foot tower, which cured my problem. You do not want to run a pole that high as it will bend in the wind. Every install is different due to location and surroundings. I would say the higher the better is the best advice I can give you at the moment. The only way to know for sure is to try it out. Going up that extra 10 feet (using the tower) cured my problem.
  5. 357magnum
    357magnum Sr. Member
    Feb 25, 2014
    2,315
    3,027
    I wanted to put a steel roof on my house . I'm also installing a Sirio 27-4 Beam . I only wanted a short mast coming out of the rotor , I asked around & told The Wife ... Conventional Shingles it is !:LOL:
    Slowmover, TIN_CAN, S&W357 and 2 others like this.
  6. Shadetree Mechanic
    Shadetree Mechanic 808 On The North Side of Dover
    Oct 23, 2017
    3,359
    4,461
    :whistle:If you do it right the metal roof will be the ground plane.
    TIN_CAN and 357magnum like this.
  7. 357magnum
    Feb 25, 2014
    2,315
    3,027
    Shade , Wouldn't work for me ( I don't think ) as I was going to mount mine on the end of my house . Depending on direction the amount of beam exposed to the metal roof would vary . I guess if you used a Tri-pod & metal was completely under beam , you might have a shot ? I just don't want to take any chance & don't feel like putting up a tower which is the way it should be done .;):confused: IMO
    Shadetree Mechanic likes this.
  8. 2NC995
    2NC995 DAN
    Feb 23, 2008
    2,219
    3,921
    You have to have a magmount beam if you want it to work right.
    gamegetter, Slowmover, Beetle and 3 others like this.
  9. 357magnum
    Feb 25, 2014
    2,315
    3,027
    dled ,(y)o_O:ROFLMAO:
    S&W357 and binrat like this.
  10. Jay Mojave
    Jay Mojave Well-Known Member
    Nov 17, 2015
    196
    324
    Hello okie: The Y quad beam antenna might be slightly effected by the metal roof. If the antenna could be higher that would be better.
    Be advised metal roofs mostly are not grounded, that means they will pick up noise, static and the such. Especially during a lightning storm.
    If the antenna mast is grounded and the upper part connected to the metal roof these noise and static energies will use the mast to flow these noises and static to ground causing a very noisy receive. And drive ya nutzoid trying to fix it. But not all metal roofs will do this. The metal roof is constructed to NOT leak and NOT fly off in heavy winds. Its NOT designed to NOT give off Radio Interference. And some do.
    I would give that antenna install a try at least so maybe if you get it higher in the further you can compare it to being closer to the metal roof. Good luck. Please let us know how it all turns out.
    okie, binrat, undertaker and 2 others like this.
  11. Marconi
    Marconi Usually if I can hear em' I can talk to em'.
    Oct 23, 2005
    6,530
    1,588
    Hello Okie. I have a model of the Maco 103C antenna that I setup Vertical.
    I also have a modeling object that I made, a metal pitched roof 17'H x 30'L x 38'W.
    I set this vertical M103C model on a mast connected to the ground and 2' feet from the building at its peak. The bottom of the vertical elements are about 7.5' feet above the 17' foot roof peak.
    Note: these models do not necessarily represent what will happen at your location.
    I think Jay gave you a reasonable expectation in answer to your question and I see the models below in support of his suggestions.
    Models in the PDF file below.
    1. shows the starting model, a vertical Maco 103C with no metal building.
    2. shows the beam 2' feet from the metal roof of a building and pointing North over the roof top.
    3. shows the same view as #2 with the beam pointing South away from the metal roof.
    4. shows the beam rotated 90* degrees pointing to the East.
    As I rotated the antenna in these three directions I noticed the feed point match changing. So, I tweaked each model a bit to make for an improved match. On rotating your antenna in this situation...you might expect the match to vary as you rotate.
    I will also do the horizontal version later just as Unit 75 suggested, and see what modeling might suggest there as well. Again, I think Jay is right.
    Okie, keep us posted on your progress.
    okie likes this.
  12. Tallman
    Tallman W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    5,107
    5,787
    The best way is to mount it is on a tripod in the center of the roof. It will affect your radiation pattern to some degree. But the swr should be lower than trying mounting off of the side.
    okie likes this.
  13. okie
    okie Member
    Nov 5, 2010
    30
    18
    Thank you all for the help and the pdf file. I ended up breaking the antenna but not beyond repair. I had a 30' joint of 2-3/8" oilfield pipe on a tilt base with a couple of pieces of Rohn 5' mast. About 40' total. Swrs were 2.0+ but made good skip contacts and talked to several base stations 45 or so miles away. Layed it over and added 2 more pieces of Rohn mast pipe and should not have. The mast broke on the way up and the Y quad was bent badly on the rejection side. Ordered a 103c from Copper but am going to try and repair this or maybe use the parts to build a vertical or something.
    Going to put the 103c up on the piece of 30' oilfield pipe with one 5' Rohn mast and call it good.
    Again, thank you for all the advice. Was working well until I started trying to go taller and taller. .... live and learn
    357magnum and Shadetree Mechanic like this.
  14. Shadetree Mechanic
    Oct 23, 2017
    3,359
    4,461
    That Rohn pipe as well as the top rail fence pipe seem too thin. I did a tilt over with 10 foot sections of water pipe. I would love to have used a 30ft section like you did. Here is a link to the Vector 4k install that I did with the tilt over mast.
    https://www.worldwidedx.com/threads/sirio-new-vector-4000-install.226677/
    357magnum and okie like this.
  15. Tallman
    May 1, 2013
    5,107
    5,787
    Is your Oil field pipe drill string or completion tubing?
    357magnum likes this.
Share This Page
  • About Us
    The WorldwideDX Radio Forum was originally established in 2001. We pride ourselves on welcoming Radio Hobby enthusiasts of all types, while offering unbiased, informative, and friendly discussion among the members. We are working every day to make sure our community is the best Radio Hobbyist's site.
  • Like us on Facebook
  • Premium VIP Member
    The management works very hard to make sure the community is running the best software, best designs, and all the other bells and whistles. Care to buy us a beer? We'd really appreciate it!
    Donate to us!
