I would look at the TNT 350HD, 2 2879's, biased b, and are well built. Max input is 120 watts pep with a 2-4 watt dead key. Made by xforce. That will get you to the 300-400 watt area with the optima radio behind it. And they do a great job on ssb. I get compliments all the time, I run an older version of the TNT 350hd, the magnaforce 350hd, with a magnum 257hp. I have made contacts all around the world in mobile with this setup and have always been told that it sounds good. Had one guy say it sounds bodacious!! JMO. Look into the TNT amps by x-force, they are well built amps and can handle a good deal of input power as well. The TNT 350hd specs are as follows:
Transistors 2 x 2SC2879
Dimensions H 4 1/4' x L 7 1/8' x W 41/4'
Amp Draw (maximum) 29
Class B biasing
SSB Delay auto
Pre-amp yes
No Driver Required But T100-M Optional
Max Dead Key 100 Watts
Modulated Output (RMS) 150 Watts
Modulated Output (PEP) 400 Watts
install recommended with 8ga wireand 50a fuse.
Max input carrier of
5w or 100w max carrier from amp.
Max peak input 120w.
