first check the relay.
make sure it is engaging and disengaging properly.
if not, good luck. you'll need it to find another one.
if relay checks out ok; try replacing C179 (near final and driver) with a 2.2uF 25v electrolytic capacitor. (stock part is a tantalum cap, and is notorious for going out.)
if thats not the problem, the driver is a 2SC1306, which isnt made anymore, but you can replace it with a 2SC2166.
the final is a 2SC1307, but again, not made anymore. can be replaced with a 2SC1969, or an NTE236. (1969 preferred)
you must re-bias the final and driver when replacing either.
driver should be at 40mA
final should be at 70mA.
also be wary of the MV1Y diodes that are heatsinked to the driver and final. if you cant bias the driver and /or final.
its a good guess that these have gone. best to replace with original part from junk radio.
also, while you are messing around inside that radio; all of the 2SC1419's should be replaced with NTE152's.
the one near the PLL should be moved to a big hunk of metal inside the chassis, and have wires going to the PC foil traces.
check for burnt foil traces near this transistor and the big resistor covered in teflon behind it.
best of luck, great radio!
loosecannon
