RigExpert AA-35 Zoom
Riverman
Sr. Member
I Support WorldwideDX.com!
Nov 12, 2013
3,079
3,456
273
Have had this a while now. Here's a review.
Bottom line: it works great. Current price: $218.95 at HRO.
Comes with USB cable, batteries, and carrying case.
In action on my 10 meter vertical:
That's it. Good analyzer.
A friend of mine bought one, and let me use it. It does work good.
My friend was having a random problem with his radio setup. Tracked it down to a bad connector. The meter made it easy to see the SWR fluctuating up and down doing a jiggle test on the coax and connectors. Meter would show SWR at 1.2, and then randomly jump to 10. Ten SWR is not good!
Just wish it had a setting for 11 meter. Have to manually input the frequency.
Reactions: Riverman
be careful when using the AA-35 Zoom (and possibly other Rig expert analysers) on a non grounded antenna system like an open dipole. Always short out the antenna lead to ground before fixing to the Analyzer as built up static can and has wiped out the little resistors on the input of the analyzer rendering it useless till they are replaced.
Seen it happen.
I'd love to have an analyzer but, I'm not sure I could ever figure out how to use it. I have a lot of antennas and It would be quite a learning curve figuring all of them out. And, quite a bit of fun I imagine. But, they seem fairly complicated to an old Southern Missouri country boy...
The RigExperts are not at all difficult to learn and use. Bought an AA-55 ZOOM a few months back and after a few hours of playing was able to tune my antenna better than ever before. Better than sliced bread. You won't be sorry for buying. Good used units pop up now and then on QRZ for reasonable prices.
Thanks to Night Thumper for nagging me into buying it.
Thanks for the info. I'll be checkin' them ever now and then.
Reactions: Crawdad
I've been lookin online at the AA-35. It's a bit cheaper but, I doubt it will read everything the 55 does. Probably be fine for me though.
Reactions: Crawdad
I believe the AA-35Zoom does everything the 55Zoom does just at a lower max frequency. I bought a 55 to have the ability to do 6m antennas. If you don't intend to do VHF then a 35 should do you fine.
Reactions: Groundhog KSS-2012
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
