STRYKER EXPERT NEEDED
  • Thread starter Thread starter W1R3T4P
  • Start date Start date
If its coming from the ECM, then there will be some way to block it at the ECM. Not knowing jack about the CAT motor configuration and parts location, I can't even begin to tell you how to do that, but if the ECM is the source, then there IS a way to block it.
DTB Radio said:
Keep in mind that it has to be something electrical/electronic generating the noise as you search for the problem. Here's an idea that I personally have never tried before, but might help in finding the source. Build or buy an RF sniffer probe, and look around for RF in the engine and dash area when revving the motor. If there's some way you can put the truck on a dyno and do this with a load on the engine, even better yet.
Has to be manifold pressure(turbo boost) 20 psi and above in order for the problem to appear.
Someone should forward this to Cat for what it's worth. They are very tired of me :P
Hey Dave you have PM....
