texas star 400
Ok the way i had it to work was if the am and ssb buttons are pushed in at the same time if i push am only it sticks..
I wouldn't operate it if you know it is smoking - or else it might have a complete failure. The output looks OK, so the finalss should be OK. Sounds like you are over-driving the amp. BTW, you aren't using a Cobra 29 if you are going to sideband; so I suspect you are over-driving the amp!
