Uniden pc122xl no tx or rx
Only thing that comes to mind that it may be the transistor in the back of the radio near the power connector. You can use a TIP42 in place of it. Unsure if that only deals in AM and not the SSB side of things. Even if it doesn't fix it, it is a good idea to replace it from what was there originally.
  • Haha
Reactions: sp5it
Gday
This is the transistor i pulled its a toshiba 2sb753 checked it with dvm and its working im guessing it just a bad cap finding it is a different story i was thinking of an esr meter so i can test them all in circuit
Thanks joe
Hi
I have found no voltage at pin 16 of pll and ic5 has 6 volts at pin 6 so i think the ic5 is working im still to track down the missing voltage some other component has failed any ideas
Thanks joe
I did this on a hunch with a simular radio.
Find test point 2 and measure voltage to board ground/ not chassis ground, on channels 1 and 40. Remember the number on 40, while keying slowly turn L13 to its max top and bottom while watching your watt meter for movement. record max and min voltages, or the voltage that lit up the watt meter. sometimes the specified 4.5 0n 40 isnt enough...
Gday
Have found both pin 15/16 of pll has no voltage and channel display is missing segments like theres not enough voltage there to power the display
Thanks joe
