New profile posts
I built a 2000 brand new.. I put in FM and a Amp inside the main cabinet with a power suply in one of the speakers and an Octal plug between one speaker and the radio... Lots of channels also!!!
little dx coming in Alaska 4pm my time, I seem to find dx on ch 6
Reactions: Newbie solar guy
Newbie solar guy
Newbie solar guy
We go on 23,28 alot.we are out of Pahrump Nevada. "Rick944 or "Lady Di out of so.nev." if you here us,waive (1/2hour from Vegas) we get alot of South East area mostly Tn. Al. FL. Ga. Illinois, on the skip. Michigan and Maine couple times.73 bro.
from Marconi
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio."
No truer words ever written.
Your 422 amp: Did you notice a reduction in current for 422's compared with 2879's?
That was why I went to 28v w/ Palomar 900HD. When amp new, it wanted more current than my 40A PSU had. I have no measurements but PSU no longer strains. What are you using for 28v PS?
Neil NYC
SuperLid
SuperLid
Ohm's law does apply here. I have not used this amp in almost 30 years, however I still have it and plan to make some changes and use it. The current plan, is 6 MeanWell 28V 6.5A SMPS's in parallel. The old plan was 4 parallel Glenayre 26V 14A SMPS, removed from paging transmitters.
I need to know whether the Yaesu FT990 can easily be hooked up to an acom 1010 amplifier. What is the proceedure?
Tin Can, Alabama Buckeye here. PowerMax PM4-100 V PM3-100? I've a PM3-75 which does not have neither switch nor voltage set screw. Is that the same on your PM3-100?
TIN_CAN
TIN_CAN
Hey Alabama Buckeye, I just went to radio room to confirm, both PM3-100 and PM4-100 have voltage adjustment 13v-16.5v and switch that selects 3stage and fixed output. Hop that helps you out, I run both in tandem at 14.5v to run all my amps and radios. fans have come on once since I have owned them.
Alabama Buckeye
Alabama Buckeye
I'm interested to know why 14.5V?
I adjust my 200A power supply to 14.5V. Stryker 655 or 955 either will readout 13.7V draw. I presume a protection component in the werx
Might I guesstimate 14.5V for the benefit of greater watt output from linear amps? What boost might that be, 80W?
QTH#1:Realistic TRC-490 w/Turner Super Sidekick driving Starduster clone or IMAX 2000; QTH#2:TRC-465 w/Johnson desk mic driving A99; Marine Mobile: Cherokee AH-100 w/t driving Shakespeare 5223
Lately this new guy Rob AKA Skybanger has been making a lot of waves. He's made a lot of people mad.
