Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Hi narfedwards, looking for a copy of the Sams Photofacts CB-246 and I saw a posting from last year that you have one. I am trying to help an elderly friend in Montana locate once so he can get his Sears Roadtalker 40 channel SSB rig living again. Would you be so kind as to supply a copy?
Need some help hard to finf for info on Galaxy Saturn. i need alighnment info and maybe a schematic. i hope your still around to help me. thanks garyprososki@hotmail.com. any help will make my day.
I recently found a Pinto SSB Transceiver JC Penny. It is in pretty good shape. I found a small coil inside that broke off from somewhere inside. I also found a little knob has been added at some point. There was no power wire. Is this worth getting fixed and holding on to it or is it junk ?
I just ordered a Stryker 497hpc. I've heard alot of good things about them and watched a few video's. I am curious about switching it over to the AM band so it can be used as a cb. Is it hard to convert it ? Is it something I can do myself or should I do the 95 mile ride to a cb shop and let them convert it ? Any info will be helpful. Thanks.
Hello, By chance do you still have a copy of the Washington 385 board Manual that Robb emailed to you a long time ago ? I saw that you guys were corresponding in a post back in 2016 and thought it was worth a shot. I cant find one anywhere.
thanks
Maybe you can help me I need to swap out the 5 pin mic receptacle on a trc 431 radio to a four pin receptacle first I need to know if it can be done and then hopefully a diagram of the rewiring The one that is in that radio now has come free and really has no retainer other than glued plastic .
https://www.facebook.com/marketplace/item/594128368939193/
Log into Facebook
Log into Facebook
