New profile posts
buon giorno
purttoppo ho smanettato troppo nel menu service
gentilmente mi potresti inviare
gli inserimenti ( numeri ) esatti di fabbrica
grazie
Bonjour
malheureusement j'ai trop bidouillé dans le menu service
pourriez-vous bien vouloir m'envoyer
les entrées d'usine exactes (chiffres).
Merci
I Rember talking with you on C B Tricks in the forums I went by Snow Bird In Va At the time .You were the Mr Fix It Back then Glade to know what happened to you be good. My friend
Shadetree Mechanic
Shadetree Mechanic
My apologies, that must have been a different person. By the time I got into the cb hobby, the CBTricks forum was already gone. Although I think I have talked to you on the air before.
J
Johnny Waggoner
Shadetree were you on the Coppers Forum?
Shadetree Mechanic
Shadetree Mechanic
No, that must have been someone else.
Way over due but just cutting my teeth into CB. Mobile cruising with a BearCat 980 SSB and a 63 inch whip Browning BR-91-BL 15,000 Watt Flat Coil. Glad I found this forum.
BigSmole768
Is the Uniden 2600 still available?
AudioShockwav
AudioShockwav
Used ones can be found from time to time, the 2600 did not get converted to CB use as much as the 2510/Lincoln did.
Good luck in your search.
looking for a CB mobile or base amp ? anyone in or close to Milw, WI that can help me out ? 73s
Just getting my feet wet in Amplifier troubleshooting and repair. Which repair guide and where to buy it for Power supply and Linear amplifier repair?
Hi narfedwards, looking for a copy of the Sams Photofacts CB-246 and I saw a posting from last year that you have one. I am trying to help an elderly friend in Montana locate once so he can get his Sears Roadtalker 40 channel SSB rig living again. Would you be so kind as to supply a copy?
Thanks in advance!
chem_man
Need some help hard to finf for info on Galaxy Saturn. i need alighnment info and maybe a schematic. i hope your still around to help me. thanks garyprososki@hotmail.com. any help will make my day.
E
eric chilton
go to cb tips and tricks on the net they have all the info you need
I recently found a Pinto SSB Transceiver JC Penny. It is in pretty good shape. I found a small coil inside that broke off from somewhere inside. I also found a little knob has been added at some point. There was no power wire. Is this worth getting fixed and holding on to it or is it junk ?
I just ordered a Stryker 497hpc. I've heard alot of good things about them and watched a few video's. I am curious about switching it over to the AM band so it can be used as a cb. Is it hard to convert it ? Is it something I can do myself or should I do the 95 mile ride to a cb shop and let them convert it ? Any info will be helpful. Thanks.
