New profile posts
I need to know whether the Yaesu FT990 can easily be hooked up to an acom 1010 amplifier. What is the proceedure?
Tin Can, Alabama Buckeye here. PowerMax PM4-100 V PM3-100? I've a PM3-75 which does not have neither switch nor voltage set screw. Is that the same on your PM3-100?
TIN_CAN
TIN_CAN
Hey Alabama Buckeye, I just went to radio room to confirm, both PM3-100 and PM4-100 have voltage adjustment 13v-16.5v and switch that selects 3stage and fixed output. Hop that helps you out, I run both in tandem at 14.5v to run all my amps and radios. fans have come on once since I have owned them.
Alabama Buckeye
Alabama Buckeye
I'm interested to know why 14.5V?
I adjust my 200A power supply to 14.5V. Stryker 655 or 955 either will readout 13.7V draw. I presume a protection component in the werx
Might I guesstimate 14.5V for the benefit of greater watt output from linear amps? What boost might that be, 80W?
QTH#1:Realistic TRC-490 w/Turner Super Sidekick driving Starduster clone or IMAX 2000; QTH#2:TRC-465 w/Johnson desk mic driving A99; Marine Mobile: Cherokee AH-100 w/t driving Shakespeare 5223
Lately this new guy Rob AKA Skybanger has been making a lot of waves. He's made a lot of people mad.
Where is Tim Hoffman and Eric Oyen N7ZZT?
Reactions: techradioman
T
techradioman
I don't know whatever happened to either one of them, they've been gone a long time. Are you on the radio (11meters)here in Phoenix ? If so what is you name or numbers. I'm Tom 2915 in North Phoenix
357
357
Tim is on there right now sqealin....nothing more than squealin...
Couple pictures, one showing my 142 which needs some TLC and the other is a special custom mobile with same mod...
