CRE-8900 And Beyond:Ongoing Discussions
Honestly, I'd just use a 9V battery in the mic. I've had mine in the mic for 6 months of daily use and haven't needed to change it.
Trying to step down the power to run the mic is just one more "if" in the equation and it's not really necessary.
Reactions: Lil'Yeshua
Tried out the new Road Devil mic on my Galaxy DX-959 this morning before adapting it to the CRE-8900. It's L-O-U-D!!!! The RF Limited 2018 Xtreme will make the 959 do 100% modulation whole saying Aaaaah but the RD makes it do 110-112%. Can't even turn the talkback on unless I turn the RD's gain way down. This will be good talking long distance direct and for punching through on DX. :tt1:
how ya got that 2018 setup?
heres mine
audio vr max
nr off [for max audio] or on in noisy situation
mic gain on radio adjusted for clean audio [usually 1/2 -3/4 depending if nr is on
The 2018's volume gain pot is cranked all the way up,the radio's mic front panel knob is all the way up,the only limiting factor is that the 959's modulation is set for 100% modulation in the DTB Radio state of tune. This makes it loud but not into splatter. The RD kicks it over 100% and is cutting through Motor Mouth Mauls and John Denver some of the time to a another operator 6 miles away on a base with a Maco V58. I'm on my Sirio Performer PL 5000.(2018;Echo volume 8 1/2,echo delay 1 1/2, n.r. Off, D.T. On. )
Last night I got on SSB with someone I know 8 miles away. I kept turning down the 8900's mic gain to a final setting of 8. The RF Power knob was at full power and i was on the stock mic. The other guy was talking on a Lafayette 2400FM. He said that i sounded natural and not forced. I monitored my S/RF meter while i talked. It went 3/4 of full scale. I'm thinking that a mic gain setting of 8-12 would be right. I've yet to find out just how much modulation to set my radio at while talking SSB. I noticed that when I got my 8900 from DTB,the mic gain was set at 8. Hmmmmm?!
The MFJ-207 can be zeroed back to a particular frequency without a plug in freq counter. Just stick a two foot piece of wire in the MFJ's freq out and place close to the SO-239 jack on the radio having the RF gain turned all the way down. Set the MFJ close to the frequency that you want to check the antenna system with and listen to the radio for the MFJ's signal. Cool!
Of course,the radio has to have a freq counter
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
