Base Sirio New Vector 4000 Install
That is 60 pounds of gravel in the bottom so the beam doesn't sit in a concrete bucket.
My son helped me with the 6x6 beam 16 feet long. We set it on the ground and tipped it up into the hole without too much effort.
I mixed up seven bags of concrete in a wheelbarrow one bag at a time. Its 560 pounds of concrete total. I let my kids write their names in it before it completely set up.
That looks real nice. Is that snow in Texas? I see your cable goes quite a ways up the tower, I will try that to help alleviate some stress on the pipe joints. Yes a beam tower is definitely on the list.
Actually that was ice...We had a storm blow in right after I put the antenna up that was nothing but sleet and freezing rain...The pipe I used to raise the tower is old drill stem, all I had was 2, really need 3, but gets the job done raising and lowering the tower...I do have to add a cable on the back side of the pole and anchor it to the ground when lowering or raising the tower tho, to keep the drill stem from bending.
Haha! That's how I did my concrete too!......Mixed it up in a wheelbarrow, only it took "56" bags... Hole had to be 3'x3'x4'....
The rental fee for a mixer at home depot was well worth it. I had around 80 60lb bags. Home depot wanted to charge me a deposit for the pallet the concrete was on. When I told them I didnt need the pallet because I didn't own a forklift they were confused. After taking to a manager 2 guys stacked it all in my truck.
I started to do that, but after buying 60 80 pound bags of concrete I figured I had spent enough on the hole project...
Mine...
Wonderful!! I'll bet it doesn't take much output to talk all over the world (conditions considered.)
I could only imagine your receiving capabilities. Only a dream that'll never be realized. Oh well. :(
Reactions: jessejamesdallas
Talked to people in just about all the English speaking Nations at one time or another, and a few non-English Country's...Not allot of power, and not always on SSB channels either...antenna does most of the work...just a mater of getting the house pointed in the right direction!:D
I put a working platform at the top of the wooden part of my tip over mast. The wood part is 17' tall. I attached a pushup pole to it that I can, if I wish, extend to an additional 20+ feet. The pushup pole is a simple combination of 3 EMT tubing sizes. 2", 1.5", and 1.25" inside each other. When changing out antennas I can crank it over, for simpler tuning adjustments I can work from the platform then push the tubing up and pin each one at about 9' out of the one below. I do use guy ropes from just below the antenna mount point. This setup puts my EFHW at 37' right now. I once had a 40' push up pole attached that got me an additional 9' up. One section got jammed up so I took it off in favor of the much lighter EMT. G_0245_zps4b8cf966-02.jpeg
This photo was of when I had the 40' pushup on it. It is not extended here.
