Antenna Help
jkp1
61
71
28
68
Indianapolis
Hey guys,
I'm fairly new to CBing. Actually started using one as an Oversize Load Escort. I had Uniden 520 with a Wilson 1000 magmount, which worked fine. But being OCD, I want to learn and improve the system. Right now, I'm focusing on the antenna. I bought a MFJ 259-C, and have been playing with it. My question for today is what should my antenna line loss be. I have readings between 7 and 8 db. Isn't that pretty high?
I don't think you have a way to disconnect that antenna from the coax.
The "coax loss" measurement can only be performed with the coax disconnected at the far end from the analyzer.
Leaving the antenna connected will disrupt this measurement and make the reading meaningless.
Yeah now I see the antenna type. Missed that the first time around. Like I said the antenna can not be connected when doing line loss measurements.
OK if you want to improve the antenna then do this:
1) Bin the magmount.
2) Go to www.k0bg.com, read up the sections on mounting, grounding and bonding.
3) Choose an antenna with a stainless steel whip such as a Sirio Performer 5000 that can use a fixed mount and get a puck mount from Breedlove Mounts, expensive but they'll outlive the vehicle. Drill a hole in the middle of the roof, install fixed mount.
4) Do bonding.
If you measure the frequency where X=0 before you start doing bonding then you'll notice as you do the bonding, without adjusting the antenna the frequency where X=0 starts to drop and this is proof you are improving your RF ground. You should find that when you've finished bonding that the antenna SWR is below the CB band, there's not enough adjustment and you have to physically cut the whip.
Hey thanks MOGVZ. I've read everything on k0bg's sight, some of it multiple times. I have a Sirio antenna, I just haven't commited to drilling the hole. I have done some bonding, but I didn't have the MFJ when I did it, so I can't do a before and after.
I think I do need a longer whip. I had the antenna tuned with an analyzer once and with resonance centered on channel 20, SWR's were higher on 40 than on 1. DA me shortened the mast to flatten out the SWR's instead of leaving it resonant.
I've been busy and not taken the time to mess with the antenna much. The next project is to try and see if if it makes a difference where on the roof the antenna is mounted. The roof has ribs on it and I can't mount it directly in the center. The Breedlove mount would have to sit off to one side. I've thought about mounting it near the back, behind the ribs. Another advantage off that location is not having to take down the headliner.
I've also been undecided between LM400 and RG8X coax. With the RG8X I could make a choke, not smooch with the LM400.
Thanks again for the input. When I get time to do some more experimenting, I'd probably have more questions.
Given the damage a mag mount could do (it’s potential), the only pain with a proper antenna mount is a specialized drill bit.
But, pain will turn to pleasure in re that sunnava who divorced your sister leaving her high & dry. Next week he’s back on night shift . . .
Reactions: rabbiporkchop
This seems to be the cleanest way to make a perfect hole.
Kinda pricey at 35 bucks but totally worth it.
Reactions: 357magnum
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
