If you live within a mile or so of any train tracks and you haven't noticed the band filling up with carriers, it's only because Positive Train Control has not be installed in your area yet. The device in question transmits a 27 MHz. signal from an antenna under every train. This signal is only used to power remote receivers on the track that are recording the trains location and other perimeters. This 27 MHz. signal cannot be interfered with since it carries no information and is only a remote power source. The 27 MHz. RF is rectified into DC on the track.
The entire system is in violation of multiple FCC rules that are not only being ignored, but the equipment being used seems to have been carefully designed to CAUSE interference. First, the CB band allows use of remote control devices only on designated RC frequencies. Since this system is using CB to remotely power another device, it is by definition a remote control device and could only be authorized on RC frequencies.
The fundamental frequency this system operates on is channel 13 but it is loaded with spurs that appear every 40 KHz. up and down from channel 13. The first lower spur lands right on channel 9. Unfortunately I've been unable to find any FCC type acceptance information regarding this system. Not even a file number to look up. If you are within a few blocks of any train tracks the spurs are strong enough to extend right into the CW portion of 10 meters!
I wonder how long before every train in the country has a PTC device installed that could never pass any FCC inspection or rules? What's going on here and who ignored every regulation to press these filthy RF generators into service on the air?
