The Search for the Perfect Antenna . . .
I didn't want to drill another hole in my wall of my house.
Probably won't.
I was referring to the panel outside. There is a ground bus bar that wires can be attached to. Usually many open spaces, takes a flat head usually. Knock outs on the box allow additional access. You can add conduit if you are anal or just run the wire out to a rod with a ground lug. You may have one already. Check for corrosion if existing is present. You could facilitate the existing ground wire from elect outlet by adding a jumper out to ground lug on unit.
I currently have one hole in wall for coax. Would need a other for ground wire. Have yet to do it. No problem with any of my other antennas. Just this one. Will likely drag one of the others out rather than my drill. :cool:
You need more impedance, and more Advil
Am already maxed out on Aleve for my achin' back.
Another problem has presented itself and a google search revealed NSAID medications like Aleve, Advil and Motrin often cause constipation. More impedance is the last thing I need right now. o_O
OMG!!!!:eek: Way too much information there Riverman. But, may I suggest some prunes and coffee?:coffee:
Reactions: Riverman
